Zone T5 suspension lift
Discussion in 'Suspension' started by Koloheboy25, Mar 26, 2019.
  1. Mar 26, 2019 at 11:30 AM
    Koloheboy25
    Koloheboy25 [OP] New Member
    Kekoa
    2017 Tundra
    I have been looking into a quality lift that won’t kill my wallet and found a lot of people recommending the Zone T5 lift. When reading about it under “Important Notes” it states the stock 18” rims cannot be installed. So I’m other words I cannot put back on the stock rims and tires after the lift kit install? Just want to make sure I have my aftermarket rims and tires ready if this is the case
  2. Mar 31, 2019 at 2:24 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    That is true. You can run 18" wheels/tires... just need more offset than stock setup. Need to be in the 12 to 20mm offset range most likely. I am running 35x12.5x18's on the truck in my avatar. Zone T5 lift...
  3. Mar 31, 2019 at 2:26 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Do u off-road much? What are ur plans with the truck?
  4. Mar 31, 2019 at 2:42 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Yeah, you'll need spacers to use the stock rims
