Zmax and other Micro Lubricants
Discussion in 'General Tundra Discussion' started by sprtbkr, Aug 3, 2018.
  1. Aug 3, 2018 at 6:04 AM
    sprtbkr
    sprtbkr [OP] Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    Do any of you use Zmax or any other micro lubricants? Do they work, or are they just snake oil? It used to be Slick50 was all the rage, but now you don't hear anything about them.
    I just did my first oil change on my 2018 at 2500 miles. I couldn't stand the thought of 10,000 miles to my first oil change on a new engine. :)
  2. Aug 3, 2018 at 6:10 AM
    timmy2112
    timmy2112 New Member
    2013 CM
    I am no expert, but my vote is snake oil!!
    GNTundra and sprtbkr[OP] like this.
  3. Aug 3, 2018 at 6:13 AM
    sprtbkr
    Scott
    Denver, CO
  4. Aug 3, 2018 at 9:36 AM
    tundras00
    tundras00 New Member
    Never fell for crap like this even when I was a teenager. Don't do it!
    sprtbkr[OP] likes this.
  5. Aug 3, 2018 at 10:25 AM
    sprtbkr
    Scott
    Denver, CO
    I was raised a skeptic, as well. :) I try to research the heck out of something and then make up my mind.
    tundras00[QUOTED] likes this.
  6. Aug 3, 2018 at 11:04 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Someone should name their next additive "Snake Oil". It Slithers through your engines critical parts.........
    Vr0ck and sprtbkr[OP] like this.
  7. Jan 17, 2019 at 6:58 AM
    Gts bruce
    Gts bruce New Member
    Have used marvel mystery in a poorly maintained 4 stroke blower,grass cutter,etc small engine.Drain some crud oil and add marvel mystery. Run to warm up but use no load. You would not believe the crap that drains out. Drain well. Replace with synth. Run. Check for cleanliness and redo if oil turns foul and crudy after a short run.
    Black Wolf likes this.
