Zero point calibration
Discussion in 'Wheels & Tires' started by Joeshaker, Nov 3, 2016.
  1. Nov 3, 2016 at 10:32 AM
    Joeshaker
    Joeshaker [OP] New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I'm taking my truck in for the zero point calibration in a couple weeks. They said it wouldn't be an issue to go up to 275/70/18 from 275/65/18 afterwards. Now I'm thinking about getting 285/70 instead. Anybody know if that will cause it to need to get done again?
  2. Nov 3, 2016 at 10:25 PM
    Nah. I wouldn't worry about it unless you went with a true 35" or larger
    Law323 likes this.
  3. Nov 4, 2016 at 4:43 AM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Cool, then I don't have to rush to get the tires. What about adding a couple cb shims? Probably just one to get rid of the drivers side lean. That I should do before hand, I think.
  4. Nov 4, 2016 at 7:57 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Hey Sean, do you know anyone that is running nitto exo grapplers? I'm just going to get them before the calibration. Harrisdoggy on here just got them on his truck. But he hasn't had enough time to put them to the test. He's got 285/70/18 and they look awesome! I'm really close to pulling the trigger on them. But it would be great to hear how they do once they're down to half the tread. I hate spending all that money, then halfway through you've crappy tires with tons of tread.
  5. Nov 4, 2016 at 7:58 PM
    I don't, sorry. I ran the Nitto Terra Grappler G2's.
  6. Nov 4, 2016 at 8:03 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    How do they hold up? Are they good on snow and ice? That and the odd size is why I'm leaning towards the exos. The 285/70/18 is 11.50x34, should be perfect for the 2.5 lift and stock trd wheels. I stopped at discount and the guy thought they'd fit with no issues.
  7. Nov 5, 2016 at 9:20 AM
    They did well for me. Just not much of an aggressive look
  8. Nov 5, 2016 at 1:21 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I have 295/70/18 and have not done the zero point calibration. My truck seems to drive fine without it.
  9. Nov 5, 2016 at 4:21 PM
    I have 35" and did not do the zero. I also have the S/C though, so...
  10. Nov 5, 2016 at 4:55 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    So, then it's not necessary to do it? A couple guys on here think it is and my trucks vsc seems to be more sensitive after the lift. Sean, with the s/c you probably have the darned nanny turned off anyway.
  11. Nov 5, 2016 at 5:14 PM
    You're overthiking this. Just get bigger tires and go from there
  12. Nov 5, 2016 at 5:55 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Thanks Sean, I needed that. I am one of those overthinkers. That's why I need guys like you to kick me now and then to keep me looking forward!
    kmsurring and T-Rex266 like this.
  13. Nov 5, 2016 at 6:58 PM
    I'm an over thinker too. I just try to take my own advice. Usually works out for the best. :thumbsup:
    zcarpenter92 likes this.
  14. Nov 5, 2016 at 7:07 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I listen to myself to, just takes a minute to believe myself!
    T-Rex266 likes this.
  15. Dec 6, 2016 at 7:12 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Don't want to sound dumb...........but what is this zero point calibration I here you talking about ?
  16. Dec 6, 2016 at 8:27 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    When you change the level of your truck, the truck gets confused and triggers the traction control. You can recalibrate after adding a lift or level.
    NewImprovedRon likes this.
  17. Dec 9, 2016 at 6:33 PM
    CM-LENNY
    San Diego, CA
    Thanks Joon. I assume this needs to be done at the dealer and is their a cost to it ?
  18. Dec 9, 2016 at 6:43 PM
    CM-LENNY
    San Diego, CA
    Thanks Gino........Joon is pretty good at that stuff huh !
    GNTundra likes this.
  19. Dec 9, 2016 at 8:13 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I haven't done it, just read it researching whether I would need to. But looks like it can be done with techstream. And I think I read you can do it manually. @cdkenne ?
  20. Dec 9, 2016 at 9:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    We'll see on Sunday.
  21. Dec 11, 2016 at 8:37 AM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, mine went crazy each time I did anything with the lift for like the first mile or so then settled down. I have only put a few miles on it since the bigger tires went on. I'm gonna wait and see how it does before taking it in. But will probably just get it done for peace of mind if it acts weird at all. This is the first truck I've ever had with nannies. My 2000 tundra didn't have any that stuff so I'm not used to it. The first couple times I had to floor it pulling out of weird spots and it cut the thottle I was like...what the f!? It was totally stock then and I don't want it to be even more sensitive. We'll see, with a few more miles, what effect having the center of gravity close to four inches higher has.
