Your timing belt may last over a 100K but your water pump might not
Discussion in '2nd Gen Tundras (2007-2013)' started by bleach, Feb 16, 2020.
  1. Feb 16, 2020 at 9:47 AM
    bleach
    bleach [OP] MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I changed my timing belt on my 07 with 4.7L over the week end. While I was pulling off the covers, I noticed this pink crusty stuff on the drivers side of the pump by the belt idler. Apparently the water pump had leaked. The leak must have sealed itself after a while or the PO put some stop leak in the coolant. Either way it's a very good idea to change the pump as the job to replace it will involve the timing belt.
    The pump itself looked visually fine but there was a leak at the air hole.
  2. Feb 16, 2020 at 9:49 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s why they always advise to change the water pump at the same time as the timing belt.
    bleach[OP] likes this.
  3. Feb 16, 2020 at 9:51 AM
    bleach
    DJ
    Battle Ground, WA
    Yeah, a leaky water pump may get you to change the timing belt in time before it breaks.
    15whtrd likes this.
  4. Feb 16, 2020 at 9:53 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah, I would imagine it be a good idea to change the belt if your water pump went out close to the time that the belt should be replaced. Although a water pump is much easier to do alone then the timing belt.
  5. Feb 16, 2020 at 9:55 AM
    bleach
    DJ
    Battle Ground, WA
    It looks like you have to pull everything apart as you would the belt on the 4.7
    15whtrd likes this.
