Yo I got a stoopid bolt question
Discussion in 'Audio & Video' started by BLONGTX, Jan 14, 2022.
  1. Jan 14, 2022 at 10:12 PM
    BLONGTX
    BLONGTX [OP] New Member
    SAN ANTONIO
    2019 Crewmax 4x4
    So I was buying 10mm bolts for my ground wire, I saw HD had stainless and brass bolts. I bought both on the chance that you folks would tell me which one would conduct better. I am seeing contradictory results when I google that question.
  2. Jan 14, 2022 at 10:16 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Honestly doesn't matter for ground. I don't think any car mfg uses anything other than steel ever. Dissimilar metals and what not.
    In the spirit of answering your question brass is prolly around 3x the conductivity of steel. But for ground purposes it's like trying to make your oil oilyer
  3. Jan 14, 2022 at 10:17 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Stick with stainless. Can't go wrong with stainless
    MadMaxCanon and alb1k like this.
  4. Jan 14, 2022 at 10:31 PM
    BLONGTX
    SAN ANTONIO
    2019 Crewmax 4x4
  5. Jan 14, 2022 at 10:34 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Then use brass. I would use stainless.
  6. Jan 14, 2022 at 10:39 PM
    BLONGTX
    SAN ANTONIO
    2019 Crewmax 4x4
    Welp , I would normally always use stainless for anything and everything on a vehicle. But I just saw Madmax response so maybe I'll go with brass, he said brass is 10000x better.
  7. Jan 14, 2022 at 10:40 PM
    MadMaxCanon
    Do you have a pretty firm understanding of the principles of electricity?
    Honestly not trying to sound like a condescending asshole but it is almost a completely pointless concern.
    Is it better? Yes, does it matter for ground? Nope.
  8. Jan 14, 2022 at 10:42 PM
    MadMaxCanon
    Lol 10000x better would be like comparing rubber to silver, I only said 3x
  9. Jan 14, 2022 at 10:44 PM
    BLONGTX
    SAN ANTONIO
    2019 Crewmax 4x4
    Well, I work with low-voltage cables on a daily basis. All my cables are 100% copper so I have no idea what happens on non-commercial installs. If I had a copper bolt I would use it, since I don't I was asking about the best alternative.
  10. Jan 14, 2022 at 10:48 PM
    MadMaxCanon
    Ok well that kinda makes sense based on your job why you are asking. In the context of your work it would be a far more legitimate concern than grounding of your trucks wiring. Brass is mostly copper so it's better than stainless, but brass still an alloy so it's not nearly as good as copper. But still, stainless will work 100% as effectively as brass for your truck.
    BLONGTX[QUOTED][OP] likes this.
  11. Jan 14, 2022 at 10:50 PM
    MadMaxCanon
    I would have to find and dustoff my electrical conductivity and materials text book to give you an exact, scientific answer but I am sure you get the idea.
  12. Jan 14, 2022 at 10:58 PM
    BLONGTX
    SAN ANTONIO
    2019 Crewmax 4x4
    I guess I'll try brass because I have them. maybe I'm looking too much into this...
  13. Jan 14, 2022 at 10:59 PM
    MadMaxCanon
    You are, but I appreciate overkill myself.....
  14. Jan 15, 2022 at 4:02 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I do know that if you break the head off the brass one it will be a lot easier to drill out than the stainless one…
    I am not sure it will make that much difference myself. I am guessing you are bolting a copper ring terminal against the steel body of the truck. It will probably be a little better conductivity with the brass bolt but all of the body grounds I have ever seen on an automobile were steel bolts to steel bodies.
  15. Jan 15, 2022 at 4:20 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
