Yet another brake rotor thread...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Charliebrn, Nov 21, 2021.
  1. Nov 21, 2021 at 1:59 PM
    Charliebrn
    Charliebrn [OP] New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    My 2017 has a slight shimmy in the wheel when I hit the brakes at 60+ until they get hot. When I put the snows on, I noticed the pads are getting down there, so ordered some Akebonos. I've had them on many vehicles in the past and I liked them a lot...low dusting and yet they seem to grab better at all temps than OEM.
    Trying to research rotors, I see Hart, Detroit Axle, Raybestos, Powerstop, AC Delco, Callahan and OEM. From what I'm reading in the other threads, seem to be a lot of complaints about the original equipment... I'm curious as to a more updated list of happy customers of rotors...in particular any of the above... I'd really like something coated, as I'm definitely in the rust belt, but want reliable, smooth stopping too. I see a lot of talk of powerstops...but not so sure oabout drilled/slotted..I've had them, and they were always noisy and "grindy". lol. I tow a camper on occasion, but don't do off roading...nor am I a hard driver...I'm easy on the truck and it's brakes if I can help it
    Flame suit on for another brake thread, but really interested in some of the other brands, and direct experiences.
    Skew12 and D4x4TRD like this.
  2. Nov 21, 2021 at 2:01 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Just go with Stoptech cryo and be done with it.
    Tundra234, Rodtheviking and kparrow like this.
  3. Nov 24, 2021 at 8:11 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I'm with you there. Threw Stoptech Cryo slotted on the front and centric premium on the rear w/HAWK LTS (green) pads and couldn't be happier
    Skew12 and Hightide[QUOTED] like this.
  4. Nov 24, 2021 at 9:04 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Centric (stoptech) Cryo or high carbon rotors and Akebono pads.
  5. Nov 26, 2021 at 8:54 PM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    I went cryo rotors and yellow pads, could not be happier. FYI, I burn through brakes in all of my vehicles so OEM seldom works.
  6. Nov 27, 2021 at 3:56 AM
    timsp8
    NY
    I’ll fifth the stoptech cryo. I had powerstop for about 2 years and replaced with stoptech cryo and ebc yellow pads. It was a big difference.
  7. Nov 27, 2021 at 4:02 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I have the EBC brake kit and love it.
  8. Nov 27, 2021 at 5:42 AM
    +1 on the StopTech Sport cryo treated, slotted only.
  9. Nov 28, 2021 at 6:43 PM
    Snowboard Tundra
    Snowboard Tundra New Member
    I run the drilled and slotted rotors from 4wP, new pads and rotors about every 40k miles. I'm hard on brakes up here in the mountains, especially with a lift and 35" tires.
  10. Nov 28, 2021 at 6:56 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Does no one suggest using OEM? I've always had good experiences just using OEM pads and rotors on my previous vehicles.
  11. Dec 7, 2021 at 7:14 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    I see a lot of mentions of slotted rotors. Why? Don't you have accelerated pad wear?
  12. Dec 7, 2021 at 7:45 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Are drilled and slotted really necessary? I feel like its more for high speed track use and not so much for a hulking truck that is cruising on highways and crawling on trails at 10 mph.
  13. Dec 7, 2021 at 7:57 AM
    timsp8
    NY
    I wouldn’t trust a rotor with that many holes in it.
    Aerindel, Sumo91, frichco228 and 4 others like this.
  14. Dec 7, 2021 at 8:36 AM
    BecauseRacecar
    Ohio
    They're not necessary at all. I see 0 people running them at the track either. I think it's just bling.
    Aerindel likes this.
  15. Dec 7, 2021 at 9:30 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I actually replaced my original rotors last year with OEM rotors purchased in November and didn't get the chance to replace them until January this year, and they got warped pretty bad on a trip to Santa Cruz.. ordered OEM rotors 3 times and my orders were canceled so I opted for Stoptech cryo treated rotors... Eitherway replacing the driver side caliper since its starting to seize up
  16. Dec 7, 2021 at 9:52 AM
    MadMaxCanon
    The cryo treatment i am sure is a huge benefit. I would imagine standard rotors with the cryo would be more than capable for the tundra. I am only on 10k miles on the truck with stock size tired and I feel like that is about the limit of the stock brakes. Moving to 35s soon with 5.29s and a mild lift, I know I will need to upgrade brakes relatively soon, especially for all the mountain driving.
  17. Dec 7, 2021 at 1:33 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I’ve got 9k on mine most of the time with 35” tires and 5:29 gears it is under braked. I am pulling light trailers and driving heavy footed . Mine has a little vibration starting right as I press the brakes. I used to sell auto parts for 20ish years Akebono or EBC brake pads and cryo rotors is a good idea or a big brake kit in the future if I supercharge mine.
  18. Dec 7, 2021 at 2:16 PM
    MadMaxCanon
    Good to have confirmation of what i suspected. Ill look into upgrading. Do people usually do green or yellow stuff for these trucks when they dont tow alot?
  19. Dec 7, 2021 at 4:24 PM
    PeakIT
    PeakIT Old Member
    Utah
    I sold green EBC more often for street track cars and had them on 2 of my race cars and my wife’s Subaru that always squeaked until we put green EBC on cryo rotors . I sold tons of akebono they make Subarus factory pads or did then.
  20. Dec 7, 2021 at 4:36 PM
    Aerindel
    Aerindel New Member
    Montana
    Yep. Its been proven. It's simple thermodynamics. Solid rotors stop better and last longer. The only people who use them are people who either don't know better, or just like the looks.
