Yes, another rust opinion
Discussion in '1st Gen Tundras (2000-2006)' started by Jk70, Sep 16, 2020.
  1. Sep 16, 2020 at 7:12 AM
    Jk70
    Jk70 [OP] New Member
    Chapel Hill, NC
    I know, I know. We need another rust question. Anyway, I may go look at a 2005 Tundra AC 4x4. Dealer has been great so far and sent me the below pics of the underside. This is attractively priced with 240k miles. Advertised price is $5800 at the moment.
    According to the toyota site this was done at 170k miles: FRM. INSP/RMV. BED/RMV. RUST/CRC APPLY DLR, RENTAL VEHICLE THRU ENTERPRISE, REPLACED BROKEN BODY BOULT
    Pics: what's everyone think? And, yes I will check it out if I deem it worth it but all these trucks (which amounts to maybe 4 or 5 at most) are 2+hours away so doing my research prior to actually checking it out. Just want to make sure it's worth it or not to drive 2 hours to see yet another tundra or tacoTund1.jpg Tund2.jpg Tund3.jpg Tund4.jpg Tund5.jpg Tund6.jpg Tund7.jpg
  2. Sep 16, 2020 at 7:27 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Everyone has there own line they'll draw. That truck is beyond the line of what I would consider acceptable.
  3. Sep 16, 2020 at 7:27 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    That seems like a pretty healthy amount of rust for your neighborhood.
  4. Sep 16, 2020 at 7:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That looks pitiful. I wouldn't even consider buying that truck. Also, being in North Carolina there is no reason why you shouldn't be able to find a Tundra that isn't rusted out.
    Black Wolf and bmf4069 like this.
  5. Sep 16, 2020 at 7:33 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    That's a fair amount of rust, an I'm in New England an quite used to rust being a normal thing. May be worth going down for a closer look. If its surface rust then it might be worth it but some spots look pretty bubbled up. To me it's one of those things. You can't stop it. You can only slow it down. How long do you plan on keeping the truck? If your looking for something cheap to get by a few years then the toyota will run forever. The body/frame won't in that condition.
  6. Sep 16, 2020 at 7:55 AM
    Jk70
    Chapel Hill, NC
    I have been looking for awhile now and it's difficult to find one from 5-7k range, rusted out or not. Either it gets purchased in literally a few hours I've seen or they're 3-4 hours away. I've given up traveling 3 hours each way for a vehicle. Either way, there aren't many around
  7. Sep 16, 2020 at 7:57 AM
    Jk70
    Chapel Hill, NC
    Actually, this truck spend a long time in Vermont. I am looking for a $5-7k 4x4 Access Cab that, at that price point, I understand won't be perfect. I would love to have it last 10+ years but would be okay if it gave me 3-4 years without too much hassle. I do like to tinker around with cars but by no means a mechanic.
  8. Sep 16, 2020 at 8:09 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    That's a healthy amount of rust for sure, especially if only 60k miles ago they removed the bed to repair the rust. It looks like someone might have painted rust protection on, and usually that stuff just seals in rust, or if it gets chipped will let rust grow underneath and even exacerbate it.
    I'd keep looking. They should have done the repair right and just replaced the whole frame. That's not all that uncommon of a repair, at least from Toyota, I've heard.
  9. Sep 16, 2020 at 8:16 AM
    Johnders2586
    Alot of guys really get bent out of shape about rust understandably. If this is all you can really find an your in need of a vehicle. Go look at it just check the frame over real good, bang around on it a bit. Make sure the metal is still solid underneath. If you end up with it spend some time scrapping off the loose stuff an treat it with some sort of rust inhibitor like maybe POR 15 an then hit it a few times a year with some fluid film or equivalent an you can stretch it out with some regular maintenance. As long as it's mostly surface rust.
    Luckydog likes this.
  10. Sep 16, 2020 at 8:25 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    And it kind a looks like it had a hard/rubber coating thing done. And it's peeling off in chunks. Not good and I hate rubber coating.
    JohnLakeman likes this.
  11. Sep 16, 2020 at 8:48 AM
    Pass. There's an exhaust hanger on the drivers side cat that's down to about a human hair's thickness, eroded from rust. The body mount pictured is almost eaten through with rust. There's a portion of the frame pictured that looks like that section of floor you step through in a mobile home. Rear diff cover looks ready to disintegrate. Hard pass. There isn't a good price for a truck that will be nothing but trouble. Unless it's $800 and you want the motor and trans out of it. Imagine trying to replace a simple part of suspension on this truck. All the bolts are rusted, all the brackets are crumbling. Think of all the parts you can't see that are eaten up. See the build thread on here where the guy is rebuilding a truck with less rust than this and has already exceeded the original budget (like every project I do). Look how much work was involved as well. I wouldn't pay good money for the trouble. Head south and find a non-rust belt truck.
  12. Sep 16, 2020 at 8:57 AM
    Also, upon further inspection, where the hell did the skid plate go? Dust in the wind I imagine.
  13. Sep 16, 2020 at 9:25 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Pass - wouldn’t even bother you don’t want the headache.
  14. Sep 16, 2020 at 11:37 AM
    Professional Hand Model
    Hand Protectors
  15. Sep 16, 2020 at 11:47 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You see that bubbling paint on the bottom of the door? Imagine how far and fast that'll spread without being attended to. Rust likes to spread. There's a reason it's called cancer...
  16. Sep 16, 2020 at 1:29 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yeah, not to mention that spreading pinch weld on the bottom of the rocker panels. OP will have butt-ugly sheet metal problems long before frame issues with that one. Not a ten year truck. Too many other opportunities out there.
    mtntop, Jk70[OP] and bmf4069[QUOTED] like this.
  17. Sep 16, 2020 at 2:44 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Run away! I'm not sure what the market is in NC, but in CO, it's easy to find a rust free 200k mileage truck for $6,000.
  18. Sep 16, 2020 at 2:54 PM
    Hand Protectors
    Been looking for dayzzz for 1st Gens on shmeggsliss. No finds. Not even the usual dogs stay on for months that ‘has some rust but been sprayed under recall’. Soccer Moms Sequoias are rare, too. Rare.
  19. Sep 16, 2020 at 4:31 PM
    here's a reasonably priced low mileage example
  20. Sep 16, 2020 at 5:09 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's reasonably priced to you?
    Sundown5oh, Black Wolf and N84434 like this.
  21. Sep 16, 2020 at 5:43 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That would be me..... it's been a solid 5 months of working roughly 8-10 hours a week on this thing, and it's far from perfect. But, I've enjoyed almost every minute of it.
    I paid 2,000 for my truck, and am approaching 5,000 total investment. Originally, I figured I could do it for less than 4,000... :rofl:
    The truck in question looks similar to the condition of mine when I got it, but I had big holes in the sides of the forward box section.
    I'd keep looking.
    bmf4069 and KNABORES[QUOTED] like this.
  22. Sep 16, 2020 at 6:22 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    The fact that the rust is already eating at the sheet metal at the rocker panel below the door, and the rear driver wheel fender, I'd walk away.
    I definitely recommend looking for a southern truck from GA or FL.
  23. Sep 16, 2020 at 6:48 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    more so than 5800 for OPs
    vehicle market is crazy
  24. Sep 16, 2020 at 7:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    yea that frames got very little time left. The CRC is likely hiding a hole already. Look elsewhere. most i'd pay for that truck is 2k... because a 2700 dollar frame will be needed soon + a bunch of other parts that would break. and my time to swap it.
    bmf4069 likes this.
  25. Sep 16, 2020 at 8:31 PM
    read: sarcasm.
  26. Sep 17, 2020 at 8:14 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  27. Sep 17, 2020 at 8:22 AM
    Jk70
    Chapel Hill, NC
  28. Sep 17, 2020 at 9:05 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
  29. Sep 17, 2020 at 9:14 AM
    Jk70
    Chapel Hill, NC
  30. Sep 17, 2020 at 9:31 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Minimal concern. Overall, as long as the frame looks better than the first one you shared, it looks ok.
    probably needs a timing belt. Is that something you could handle?
    That tear in the drivers seat Bottom is repairable, at a cost..
