Yeah, I think it's time for a new battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Retired...finally, Apr 19, 2025.
  1. Apr 19, 2025 at 4:06 AM
    Retired...finally
    Retired...finally [OP] Utilizing that doctorate of procrastinatory arts
    My 21 was built 8/26/21 and now has just over 40K miles. Once home for the summers it doesn't get driven much. A week ago after sitting 5 days I noticed the starter cranking a little bit slower. After a 10 mile drive it was parked again. 15 hours later I checked the battery voltage and it was only 12.21 VDC. I put my good Iota 15 amp charger on it and after going through the bulk and absorption stages 8 hours later it went to float.
    No additional electrical devices installed and don't suspect a larger than normal parasitic drain so I'm just going to proactively replace the battery before heading south this fall.
    Fun, Fun Fun.:annoyed:
    NewImprovedRon and Corndog123 like this.
  2. Apr 19, 2025 at 4:40 AM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    Dealer replaced the battery in my truck just prior to me buying it last year. They had installed a 24F. They should have installed a 27F.
  3. Apr 19, 2025 at 4:42 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    If I suspect a battery issue.
    Using a multimeter check the voltage after parked for a few days.
    Have someone start up the vehicle while holding multimeter to terminals.
    If it drops below 10 volts change it out.
    My 2018 Tundra Toyota battery defies explanation.
    12.6 volts or more after a few days sitting without trickle charge.
    I do carry a boost pack with me that lets me air down and up and do a boost if needed.
    If I was in the US south, no way it would have lasted this long. Heat is the enemy.
    MadMaxCanon and OHwendTrd like this.
  4. Apr 19, 2025 at 4:43 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Costco Interstate 27F $120 flooded, $180 AGM
    Joe333x, Tunrod and MadMaxCanon like this.
  5. Apr 19, 2025 at 4:50 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Oh man! Well, I certainly hope that's all it is.
  6. Apr 19, 2025 at 5:28 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    3yrs is all i get out of a battery in Houston weather.
  7. Apr 19, 2025 at 5:44 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Check your battery cells once in a while. Little distilled water goes a long way.
    hagrid and 1lowlife like this.
  8. Apr 19, 2025 at 5:49 AM
    Retired...finally
    Right now it's a toss up between Sam's and Costco. I usually buy from Rural King but there aren't any near Port Aransas TX were we are going for the winter this year. I've been replacing car batteries at 5 years proactively and it's been working well. Sort of. I put a new RK battery in my Mom's Civic Feb. 2020 and didn't get it replaced until March this year. I had the new battery here on a freshening charge when she called to tell me she couldn't get the car started.
    Leo's first[QUOTED] likes this.
  9. Apr 19, 2025 at 10:42 PM
    textundra12
    textundra12 New Member
    Yep mines a 20 and I parked it 5 days and the battery was dead. I think 4 yrs is about avg lifespan
    Tyman and WILLINH like this.
  10. Apr 20, 2025 at 4:45 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    And as we all know
    batteries are
    Not what they used to be
    recycled slag produced in Mexico
    remember when optima was the go to?
    ColoradoTJ likes this.
  11. Apr 20, 2025 at 5:09 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I find it much easier to be proactive with replacing batteries. It always happens at the most inconvenient times
    nobodyintexas likes this.
  12. Apr 20, 2025 at 7:09 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Why is it that if you get a standard battery it's 27F and AGM is 24F?
  13. Apr 20, 2025 at 9:54 AM
    textundra12
    TTund16, ColoradoTJ and nobodyintexas like this.
  14. Apr 20, 2025 at 1:15 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I had a 27F AGM battery in my Tundra until just recently. Replaced it with a 24F because the 27F NorthStar battery weighed almost 70 lbs. The 24F AGM was much easier to handle/install and cranks my 2015 just fine. Age takes a toll on all of us..
    Ericsopa, nobodyintexas and bulldog93 like this.
  15. Apr 20, 2025 at 1:30 PM
    bulldog93
    Jeff
    Do you have to up the voltage on a 27F, but not the 24F?
  16. Apr 20, 2025 at 1:40 PM
    Mr Badwrench
    Mr Badwrench New Member
    I don't know what it is with factory installed batteries or tires, they have half the life of anything you purchase from an auto parts store.
    NewImprovedRon likes this.
  17. Apr 21, 2025 at 6:30 AM
    NewImprovedRon
    Ron
    NW Arkansas
    I didn't when I had my 27F AGM in my truck. I would just hook up my Noco trickle charger/maintainer to it once a month. I do the same thing with the 24F AGM I now have.
    hagrid and bulldog93[QUOTED] like this.
  18. Apr 21, 2025 at 6:33 AM
    NewImprovedRon
    Ron
    NW Arkansas
    Yep! And, how about the spare tire you get with a new vehicle, if you get one at all. Down-sized and "do not exceed 50mph".
  19. Apr 24, 2025 at 8:03 AM
    Retired...finally
    I got my new battery at Sam's yesterday and after an overnight charge installed it this morning. DOM was 2/25. On the Sam's battery rack the first one out was one dated 6/24. I stood at the tire center for almost 15 minutes waiting on an employee to help me and decided the best way to get their attention was to enter the employee only area and pick out my own battery. That got their attention right quick. The employee balked at my wanting the freshest battery saying policy was to take oldest first. I asked him if did that when he bought milk for his kids.
    Battery area on the truck cleaned and no ox grease on all the terminals and chassis grounds in the area and she spins over noticable faster now. Did find my Scan Gauge II blank and a disconnect of the Ethernet cable and reboot got that fixed. Did have to cycle through on one to bring RPM back up but the water temp and both trans temps stayed.
    NewImprovedRon, hagrid and bulldog93 like this.
  20. Apr 24, 2025 at 8:41 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Even if driven daily, you'll add time to your battery's lifespan if you saturate the cells with a smart charger once a month. Wet cell water checks, too.
