Yeaaaa, I did my 2nd self oil change today.
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Aug 5, 2022.
  1. Aug 5, 2022 at 6:15 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    It is a little easier the second time and less nerve racking. The first time I did it I replaced the oil filter canister with an all metal one. This time I didn't have to use a 30 ft breaker bar to get it loose. I was also less worried about leaks, as once I looked how the canister goes on there is really nowhere for it to leak if it is put together correctly.
    I am going to break the hell outa that front engine skid plate though. Getting it off is fairly easy but putting it back on just make me want to throw a wrench. I think next time I am going to cut the front hooks off the skid and put a couple studs and wing nuts and washers in place of the front two bolts.
    Any suggestions on how to redo the back skid bolts and make them easier? I thought about long bolts and welding a couple nuts in the middle and having just the head of the bolt stick out past the skid plate. It might be easier to start them by hand that way?
    Edit: I ended up using Royal Purple 5W-30 because they didn't have Mobile 1 ($44 for 5 quart jug) and I found a Mobile 1 canister filter.
    kevine0001, HulkSmurf14 and TILLY like this.
  2. Aug 5, 2022 at 7:07 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Been there. Bought an RCI and sold my stock plate on here. I just bought Pennzoil 5w30 for $21 / 5 quart, on sale at meijer.
    FlyingWolfe and Tyman like this.
  3. Aug 5, 2022 at 7:12 PM
    Alot of the time you can get oil through Amazon at the same price as Walmart.
  4. Aug 5, 2022 at 7:13 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I grew tired of the skid plate removal and put a RCI one on. I feel it’s worth it since I plan on keeping the truck for a long time.
  5. Aug 5, 2022 at 7:20 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I personally never saw the problem/struggle of changing the oil and oil filter with the skid plate. Maybe just me.
    Oil suggestion...you can buy a box of oil that has a bag inside it kinda like boxed wine. I buy the Mobil 1 through Walmart for about $50-60 and it comes with 12 qts and a little valve on it. Just a suggestion.
    Wallygator, omgboost and TRDFerguson like this.
  6. Aug 5, 2022 at 7:26 PM
    I got that same one and thought I was so smart, until I had to empty my oil pan back into the jug….. oh wait. I don’t have a jug :confused:
  7. Aug 5, 2022 at 7:27 PM
  8. Aug 5, 2022 at 7:28 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Where are your guys oil filter housings?
  9. Aug 5, 2022 at 7:29 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    RCI skid plate and a Fumoto valve. You’ll actually enjoy changing your own oil.
  10. Aug 5, 2022 at 7:44 PM
    the “cartridge” is on the bottom of the engine. Have to pull the skid plate to get to the plastic spin off cap. The cartridge filter is housed inside of it. My wife’s Jeep Grand Cherokee is the same way, except they wisely put the oil filter housing on the top of the motor. No less oil change that way.
  11. Aug 5, 2022 at 7:48 PM
    FrenchToasty
    Mo
    Bone stock
    Ok so it’s the same as out 4runner, rci skid and fumoto valve for the win, until you forget to change jugs halfway thru
    AZBoatHauler likes this.
  12. Aug 5, 2022 at 7:51 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Skid plate trick is to just unbolt it and let it hang, you dont actually have to remove it to get to the oil filter.
    KNABORES likes this.
  13. Aug 5, 2022 at 7:56 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I have a big container I put my old oil. I also kept 1 of the 5 qt jugs to pour it into. I need to order my Fumoto valve soon too
  14. Aug 5, 2022 at 8:14 PM
    Joe333x
    Joe333x Member
    Boston
    I almost bought that box and had the same worry, and then realized when I did the math that it was cheaper to by the jugs anyways.
  15. Aug 5, 2022 at 8:18 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I'm changing my oil tomorrow. Last time I put the MotivX kit on so this one should be a lot easier.
    Ely010606, Wallygator, Tyman and 3 others like this.
  16. Aug 5, 2022 at 8:31 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Around me, it's 50-55 for (2) 5qt jugs. Barely more you get 2 extra qts. I check the unit price each time I buy it and it's always cheaper for the boxed/bagged.
  17. Aug 5, 2022 at 8:31 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm needing to buy this as well
    FrenchToasty likes this.
  18. Aug 5, 2022 at 8:54 PM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    I cut a 5”x 5” hinged access door into my stock skid plate….definite aggravation saver!
    WILLINH likes this.
  19. Aug 5, 2022 at 8:58 PM
    Joe333x
    Joe333x Member
    Boston
    The Walmart I was at was $60 for the box and around $24 and change for the jugs so it was just slightly cheaper for the jugs per quart. For me to get the box it was have to be a decent amount cheaper since I like to have the jugs to put the oil back in. Can you funnel oil into the bag?
  20. Aug 6, 2022 at 4:48 AM
    brobert225
    brobert225 Firm grasp of the obvious
    As mentioned the Futomo valve is a game changer as far as ease. It’s well worth the cost. I also swapped to the TRD skid plate with filter door.
    coldcanuk likes this.
  21. Aug 6, 2022 at 7:14 AM
    q445187
    q445187 New Member
    2019 Tundra Limited, Premium, TRD Package
    WILLINH, CaptRussia253 and Wallygator like this.
  22. Aug 6, 2022 at 7:20 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Looks like a nice product but I’ll stick with Fumoto. If someone less annoying reviews it then I may consider it.
  23. Aug 6, 2022 at 7:27 AM
    So, if ANYONE else on the planet reviews it, then you will consider it. Just clarifying. I agree.
  24. Aug 6, 2022 at 7:28 AM
    q445187
    q445187 New Member
    When I saw the Fumoto an alarm in my head went off about the valve "switch", when I watched this video he said the same thing about branches, rocks, etc. Yeah, I know there is a skid plate. The older I get, the fewer moving parts I want, (or have that work right :rofl:). I'm sure the Fumoto is probably perfectly fine, it IS Japanese after all.
  25. Aug 6, 2022 at 7:28 AM
    Mr Badwrench
    Mr Badwrench New Member
    Are you pretty happy with the fitment of the RCI skid plate? If I ever get some play money, I'm considering getting one.
  26. Aug 6, 2022 at 7:29 AM
    q445187
    q445187 New Member
    Scotty is... different, but his videos are funny and informative. I am more of a Car Care Nut fan myself.
    WILLINH, coldcanuk and Mr Badwrench like this.
  27. Aug 6, 2022 at 7:31 AM
    Mr Badwrench
    Have you seen the parody video of scotty? Some kid nails it. Even funnier, Scotty responded in the comments with a pretty good retort.
  28. Aug 6, 2022 at 7:33 AM
    q445187
    q445187 New Member
    No, that is probably awesome.
  29. Aug 6, 2022 at 7:34 AM
    Mr Badwrench
    AZBoatHauler, Joe333x and Wallygator like this.
  30. Aug 6, 2022 at 7:35 AM
    q445187
    q445187 New Member
    I will watch that later! Thanks
