Xmas gift to myself
Discussion in 'Audio & Video' started by Pudge, Nov 22, 2017.
  1. Nov 22, 2017 at 10:58 AM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    So I decided I need to get myself something for Xmas. Its just me and my daughter and I know she's expecting Santa to bring something for me too.
    I've been dying to upgrade my stereo somehow but just don't have the money. Is there anything I can do for around $100 to give me a little bit better sound?
    I was thinking new speakers in front door may help a bit? Maybe soundproofing? If prefer something plug and play with adapters if I go the speaker route. If it's just not worth it, I'll look into getting something else.
  2. Nov 22, 2017 at 11:00 AM
    Update speakers good choice
    Pudge[OP] likes this.
  3. Nov 22, 2017 at 11:16 AM
    Pudge
    CT
    I was going to look on critchfield because they include harness and speaker adapter and free shipping this week.
    Give me options for 5 1/4 or 6.5 inch speakers. Is one preferred? Will a 6x9 fit in the door?
  4. Nov 22, 2017 at 11:23 AM
    Pudge
    CT
    Also should I try to find something under 4 ohms since I'm using the factory head unit?
  5. Nov 22, 2017 at 11:24 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
  6. Nov 22, 2017 at 12:32 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    If I read your profile correctly you have a 2015 Tundra Platinum, meaning you have the JBL Premium stereo with sub-woofer. If that is the case a 100.00 will not even touch anything.
    I have the same system and have read just about everything there is to read. Bottom line is there are no easy or cheap upgrades. All the speakers have 2 Ohm impedance (aftermarket is usually 4 Ohm) and are matched to the JBL amp. You can't just use another amp unless you also use a signal processor.
    There are some upgrade packages available from OEM+ Audio, 12Volt Tech and *********. I have read most about those systems as well and I am 98% sure I will use the JBL upgrade from OEM+ which costs 1159.00. The reviews I read are good and it is Plug & Play and fairly easy to install but you pay for the convenience. You may get by cheaper if you buy individual components but you have to know how to match them and how to adjust the signal processor...........I don't know that so I have to pay a little more.
    BakNBlk2014 and T-Rex266 like this.
  7. Nov 24, 2017 at 9:43 AM
    Pudge
    CT
    Yeah it's the "premium" JBL which is everything but premium. I was thinking a decent speaker would help if I stayed around 2 ohms but maybe it's just not worth it.
    I want to sound deaden the doors anyway. Maybe just that'll help a little bit.
    040Tundra likes this.
  8. Nov 26, 2017 at 8:32 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @Pudge maybe you wanna try this like this guy.... https://youtu.be/80stH6SGjIE
    It looks to me like it would work pretty well. I’m gonna put some in my Tundra, especially since I added 2 - 12” Kicker CVT subs.
    Pudge[QUOTED][OP] likes this.
