XD811 Unmodified platinum tundra
Discussion in 'Wheels & Tires' started by canadiantundra19, Mar 7, 2017.
  1. Mar 7, 2017 at 9:13 AM
    canadiantundra19
    canadiantundra19 [OP] New Member
    2016 White Tundra Platinum
    I am thinking about buying 22" KMC XD811. I really have no clue about this stuff... last year I had 22" fuel throttle rims with 275/45r22 tires. I really liked the look it had, but I have no idea about offset or anything. Any suggestions on what offest i would need to create a similar look with the XD811? The truck has no lift or level kit. thanksIMG_0975 (2).jpg
  2. Mar 7, 2017 at 9:18 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome from Alberta! Nice looking ride!
    canadiantundra19[OP] likes this.
  3. Mar 7, 2017 at 9:22 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    :rofl: :thumbsup:
    GNTundra likes this.
  4. Mar 7, 2017 at 9:22 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think you want to go a little wider. 285 45 22. An offset of +50 should work really well IMO
  5. Mar 7, 2017 at 9:23 AM
    canadiantundra19
    4x4
  6. Mar 7, 2017 at 9:25 AM
    canadiantundra19
    with the 285/45/r22 +50 i will not have to do any modificartions and there will be no rubbing u think?
  7. Mar 7, 2017 at 9:28 AM
    canadiantundra19
    it looks like those rims come in a 22x9.5 +35 or +12... probably no good?
  8. Mar 7, 2017 at 10:11 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    285 45 22 is basically the same height as stock. You can check the cab mount clearance with your wheel turned to full lock. 15mm isn't that much, half an inch difference, projected in a straight line from the hub, not between tire and cab mount.
