Wuh wuh wuh sound
Discussion in '2nd Gen Tundras (2007-2013)' started by Coldjustin, Nov 26, 2019.
  1. Nov 26, 2019 at 9:31 PM
    Coldjustin
    Coldjustin [OP] New Member
    Justin
    2008 Limited Crewmax
    Kenwood ddx9904s, leveled with 305/55/20 nitto terra grapplers g2's. Dual flow masters
    20191126_205328.jpg My truck has a rough country leveling kit. 305/55/20 terra grappler g2's and I have a weird wuh wuh wuh sound. It seems to be at all speeds that are fast enough for anything to even make a sound. We'll say above 20 mph. ECGS bushing has been installed along with a new left front wheel bearing assembly. The left front wheel bearing wasnt really all that bad but it does have some drag to get the bearing assembly spinning so I went ahead and replaced it. I took the right front bearing assembly out and spun it and noticed very little noise or drag. Am I just not used to this aggressive tires? I've had some pretty serious a/t tires before but nothing this wide. It seems to me like the roar would be consistent with speed if it was just tire noise but this seems like something more to me. Rear wheel bearings? Any way I can check those without a complete tear down? Up front is hard to check for me without pulling the hub/bearing assembly. I've read of the rear bearings being a pretty common failure on these trucks. Also I had an alignment and a new set of wheels put on yesterday. The sound was there before and it might be slightly worse now but not enough to say for sure. The truck also pulls left. Anyone see any issues with the alignment that might be causing the pull? Steering wheel is now off center as well. Before, it was perfectly straight.20191126_205328.jpg
  2. Nov 26, 2019 at 9:51 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Find a set of oem wheels and tires you can put on for a 20 minute test drive.
    That will either confirm or eliminate the tires, as the issue.
  3. Nov 26, 2019 at 9:56 PM
    Marty McFly
    Morty McBoonJug
    You can try posting a video of the sound :thumbsup:
    Coldjustin[OP] likes this.
  4. Nov 27, 2019 at 5:19 AM
    Coldjustin
    Justin
    I will try to get a video that shows the sound. I really think its a rear wheel/axle bearing.
  5. Nov 27, 2019 at 4:13 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    My vote is rear bearings.
  6. Nov 27, 2019 at 4:19 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Wuh wuh wuh sound
    You sir, have an acute case of "dub step". Just wait for the drop and eat the strange pill that cute girl handed you.
    smslavin, OR18TRD, SWFLTundra and 9 others like this.
  7. Nov 27, 2019 at 6:13 PM
    Coldjustin
    Justin
    Sounds fun but I'm not sure it'll solve my truck's issue.
  8. Nov 27, 2019 at 6:18 PM
    Coldjustin
    Justin
    I might get ballsy and just pull the left side rear apart and physically see the bearing and go from there. Sucks to think I'll be doing the job twice but at least I'll know then for sure it's bad. If I had any good friends with a Tundra I'd swap the wheels but all my friends are losers and drive sissy trucks like Ford's chevy and dodge. With the axle, brakes, and the entire front diff spinning I can never judge the front bearings until they are out and laying on the garage floor. Maybe I'll just do that on the rear.
    Black Wolf and Kerch71 like this.
  9. Nov 27, 2019 at 6:40 PM
    Coldjustin
    Justin
    It's too bad I can't find a rear axle "kit" for our trucks. I've seen them for titans. Simply unbolt the axle/hub/ backing plate and slide it out. Slide in the new one and put the brakes back and you're done. The ones I've seen for titans are <$250. Well worth it in my opinion.
  10. Nov 27, 2019 at 7:31 PM
    Rubberdown
    It’s probably your tires cupping.
  11. Nov 27, 2019 at 8:42 PM
    Coldjustin
    Justin
    I'm starting to believe it is my tires and I'm good with that. If I knew for sure that's what it is. Only way I'll know is to check the rear bearings. 190k is alot of miles for anything. Especially a bearing that's prone to failure on our trucks. I've spoke to the original owner who bought it new. Only thing its had in 190k miles is a ujoint and brakes and tires. If it still makes the noise after seeing and possibly even replacing the rear bearings I'll call it tire noise and drive it till the noise either goes away, gets better, or flies apart!
    JimboSlice413 likes this.
  12. Nov 27, 2019 at 9:04 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Jack up you rear, put it on jack stand, rock you wheel Top and bottom. (Top push, bottom pull then bottom push top pull) that’s the real way to test wheel bearing. If there is no play the wheel bearing is good, the front rock left to right to test tie rod.
  13. Nov 27, 2019 at 9:28 PM
    Coldjustin
    Justin
    From my experience I catch them way before they get to the point of having play in them. At work we spin the tire and feel of the front brake chamber to feel for vibration. I catch front wheel bearings well before there is any noticeable end play. Can't do that when it's spinning an axle and a differential though. Maybe I'm too paranoid over wheel bearings but I have alot riding on them.
  14. Nov 28, 2019 at 1:17 PM
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
  15. Nov 28, 2019 at 3:09 PM
    Rubberdown
    Where ya located? Maybe someone close by has a set you can borrow for 5 minutes?
    OR18TRD and Coldjustin[OP] like this.
  16. Nov 28, 2019 at 3:30 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Most likely your tires. Mine are screamers and definitely have that exact description ( hilarious btw). Sounds very similar to a bad bearing
  17. Nov 28, 2019 at 5:01 PM
    Coldjustin
    Justin
    I'm in Morristown Tn if anyone wants to make a few dollars I'd be willing to pay just for the peace of mind to know that it's just tire noise. Sad part is I just sold a set of rock warrior wheels and like new Michelin tires that came off a recent wreck. I expected the East Coast Gear Supply bushing to eliminate the noise and I had a ton of play in the left front axle before installing the new bushing. I double checked all of that work and it did make a huge difference in the noise/vibration. Now it's a different noise and I really feel like it's coming from the rear of the truck. I tried recording a video of it but it's impossible to hear it over the flowmasters. If I can't get some loaner wheels and tires I'm gonna throw rear bearings at it. Can't hurt and I'm sure with the miles they'll have some wear. Also what about draining the rear diff? Would the fluid show the metal from the bearings or are they sealed off from the rear diff fluid?
  18. Nov 28, 2019 at 5:05 PM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    I wish I were closer, I’d loan you your RW wheels back to get to the bottom of this.
  19. Nov 28, 2019 at 5:12 PM
    Coldjustin
    Justin
    It's all good. I'm very picky and its probably nothing to worry about. I done this same thing on my last 2 trucks. Go through them and make sure they are in good shape. Then drive the wheels off them. If it's a bad bearing that might literally happen.
  20. Nov 28, 2019 at 5:17 PM
    Coldjustin
    Justin
    I've had 3, 2nd gen Tundras. The first one was a 2013 with 12k miles on it when I bought it and low mileage when I traded it in. I guess that first one ruined me. Now I've bought high mileage trucks and expect them to run and drive like that first one.
  21. Nov 28, 2019 at 7:32 PM
    Coldjustin
    Justin
    I'm gonna catch a ride to a local used car dealer and test drive a Tundra for about an hour..... There's my test wheels and tires. I'm dying laughing at this thought.
  22. Nov 29, 2019 at 6:46 PM
    ND_Porkchop
    Well I ordered my ecgs bushing, and have the wuh wuh wuhhhhh sound. I usually notice it decelerating at 20mph.
    I probably should have Checked to see if it went away in 4wd, but I'll check in with OP in a few weeks once I do brakes/bushing/diff fluid change
  23. Nov 30, 2019 at 4:26 AM
    Coldjustin
    Justin
    I'm taking the needed tools home from work today to do diff fluid changes as well. Maybe the old fluid will show me where to look.
  24. Nov 30, 2019 at 6:28 AM
    Mr. Seven
    Mr. Seven New Member
    Rolla, MO
    07 DC 4x4 4.7
    Eibach Lift Level 8 MK6 18x9 ET12 295/70R18's 4.88's Auburn JBA exhaust
    OP, a few things you might try if you haven't already:
    1. Run the truck for several miles & hit your front & rear hubs & axle tubes with a temp gun. Record the temps & see if you have a large temp difference between mirrored areas (my temps run within 10*F of eachother). For reference, after a cruise my rear axle housing near hubs runs around 85*F.
    2. Try to change road surfaces while driving (chip n seal to blacktop to cement etc.) tune into the noise & see if it changes pitch. If so, may just be your tires.
    Good luck on sorting out the issue...
    Cheers
  25. Nov 30, 2019 at 7:45 AM
    Coldjustin
    Justin
    Hadnt thought of the temp gun idea. I like it! And will give that a swing later today.
  26. Dec 1, 2019 at 7:23 PM
    Coldjustin
    Justin
    So I got tired of guessing and wondering tonight. Drained and filled front and rear diff with mobile 1 synthetic. Seen no signs of metal in the rear diff fluid. Discolored badly but no serious metal. Plenty of glitter in the front but I'm sure it was from the failed axle needle bearing. Removed wheels and rear rotors and I have found my noise. Rear wheel bearings. The rear rotors are just barely hitting the backing plate at the top. Indicating wheel end play. Spin the hubs and you can hear some noise. That's as far as I'm gonna go for now until I have the parts and a way of having the axles pressed out of the bearings.
  27. Dec 1, 2019 at 8:41 PM
    Coldjustin
    Justin
    If you look right above the parking brake you can see the wear marks on the backing plate. Both sides look alike. It's actually wore a pretty deep groove. Enough to feel the wear with a screwdriver or your finger nail. Now I'll try to find a quality replacement bearing. Wide wheels and tires are hard on bearings!
  28. Dec 2, 2019 at 4:59 AM
    Mr. Seven
    Rolla, MO
    07 DC 4x4 4.7
    Nice troubleshooting! Hope the replacement doesnt give you any issues.
  29. Dec 2, 2019 at 5:30 AM
    Coldjustin
    Justin
    There's a tsb for the rear bearings. Seems my previous 2 Tundras already had the tsb done while under warranty or they fixed the faulty rear bearings on the later year 2nd gens. This is a 2008. My other 2 were 2011 and 2013. My local parts store will have 2 moog rear wheel bearing assemblies today around 5 pm. Probably gonna have to wait till next weekend to tear it down and replace them. Gotta have a way to press them onto the axle. They aren't like the front and are similar to a ford 9" rear end. No choice but to press them off and on. Now to convince the wife a $200 hydraulic press from harbor freight is a smarter buy than paying 100-200 to have someone do it for me. This will be all 4 wheel bearings and the east coast gear supply axle bushing. New front brake pads and front and rear diff fluid changes within a month of getting the truck. Throw in the $1100 set of wheels and I have busted 2 grand getting this one the way I want it. Next up. Spark plugs! 190k on original plugs is a little much.
  30. Dec 2, 2019 at 7:05 AM
    Coldjustin
    Justin
    Not to mention the $200 maestro module for getting JBL and the steering wheel controls to work. But in the end this will be the baddest meanest best looking Tundra I've owned. Smooth rolling too.
