WTS: AFE Stage-2 Si Cold Air Intake System w/Pro DRY S Filter
Discussion in '2nd Gen Tundra Parts Marketplace (2007-2013)' started by TheBeast, Apr 20, 2025.
  1. Apr 20, 2025 at 1:12 PM
    TheBeast [OP] The Beach
    Spring cleaning :)
    AFE cold air intake system. Very good shape. Freshly updated with new parts so you good to go.
    Dyno-Proven Gains up to +19 HP & +27 Lbs. x Ft. TQ (Tested on V8-5.7L Tundra)
    Outflows Factory Intake by 50%
    You are getting 3 kits from AFE.
    AFE lists the kit for years 2007-2020 (was on my 2012 5.7L)
    NOT CARB certified.
    similar to this one with polished cover instead: (#51-81172)
    https://afepower.com/afe-power-51-81174-magnum-force-stage-2-si-pro-dry-s-cold-air-intake-system
    https://afepower.com/afe-power-59-81174-magnum-force-cold-air-intake-system-spare-parts
    https://afepower.com/afe-power-90-5...store-kit-spray-12-oz-2-qty-pro-dry-s-cleaner
    pick up SoCal LB/Cerritos area
    $350 OBO. PM me.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. Apr 20, 2025 at 1:24 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    I've never looked into AFE's intake. Is this open to allow airflow into the box?
    Wondering if it's similar to Stillen's and if they sell a similar tube that goes from the grille to the box.
    Edit: Forgot about the windshield washer fluid. That would need to be relocated.
    GLWS OP :thumbsup:
  3. Apr 20, 2025 at 3:43 PM
    2 openings, yes. the round one gets fresh air from the wheel well. filter is inside the box. makes a nice ooopmh when you press on the gas pedal :)
    TacomaTRD4x402 likes this.
  4. Apr 22, 2025 at 9:03 AM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Did you happen to notice any performance gains ? Good luck with sale, I’m on the wrong coast unfortunately.
