Would you buy a set of 17" SCS wheels?
Discussion in 'Wheels & Tires' started by pbcolt, May 22, 2018.
Would you buy 17's from SCS?
  1. Yes
    73 vote(s)
    88.0%
  2. No
    10 vote(s)
    12.0%
  1. May 22, 2018 at 9:10 PM
    pbcolt
    pbcolt [OP] New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    My tires are in the last 50% of their life, so naturally I'm thinking about new ones. @SCSPerformance always has the cleanest wheel designs, and from what I hear great customer service to boot. I want to move to 17's to increase the tire/wheel ratio, I think the trucks look way better that way. Unfortunately, no 17" love yet from SCS. Would anyone else buy a set - maybe have an existing design made in 17" to save some design costs?
    Links to some SCS Designs:
    https://www.tundras.com/threads/scs-sr8-18x9-25mm-group-buy-and-initial-release.10098/
    https://www.tundras.com/threads/scs-stealth-6-wheels-20x9.1049/
    https://www.tundras.com/threads/scs-ray10-18x9-group-buy-pre-order.18199/
  2. May 22, 2018 at 9:22 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Ray 10s in 17" :thumbsup:
    BlueBottle, joonbug and Black Wolf like this.
  3. May 22, 2018 at 9:25 PM
    Motorsport36
    Motorsport36 New Member
    I have a set of 5 black stealth 6’s. Love them!!
  4. May 22, 2018 at 9:47 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    I put my vote in. I see some prerunner setup they run 17’s correct if am wrong am new to the truck game. I have my prius to run tiny tires lol i would like some meat on my tundra
  5. May 22, 2018 at 9:52 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Nope. If he woulda made 17s before I bought 2 sets of RWs though...
  6. May 22, 2018 at 10:11 PM
    Quebec
    Quebec New Member
    I will buy 17" wheels without stupid fake beadlocks. So maybe.
    BajaTurd, mtntop and Black Wolf like this.
  7. May 23, 2018 at 5:29 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    SCSwheels F5's please
  8. May 23, 2018 at 5:32 AM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    This.
  9. May 23, 2018 at 6:08 AM
    I think FN is coming out with a 17" rim. May want to check with them.
    Quebec likes this.
  10. May 23, 2018 at 6:27 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I want a set of SCS wheels in 16x8 for my first gen. Guy I work with had a set of 17's on his Taco and they looked great!!!
  11. May 23, 2018 at 10:53 AM
    Quebec
    Quebec New Member
    This is good to hear. I have FNs Countersteer Type X's on another Toyota, curious what design they're going with.
  12. May 23, 2018 at 11:00 AM
  13. May 23, 2018 at 11:05 AM
    Quebec
    Quebec New Member
  14. May 23, 2018 at 11:09 AM
    I already have a decent 18" BFD setup. If I was just starting from scratch, the 17" is the route I'd take.:thumbsup:
  15. May 30, 2018 at 10:13 PM
    Aron9000
    Aron9000 New Member
    Aaron
    I'd so rock a set of their 17" wheels if they didn't have the silly simulated bead locks on them. HATE that look, its really damn hard to find wheels without it now days though.
    UNTMatt and Black Wolf like this.
  16. Jun 19, 2018 at 12:27 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
  17. Jul 4, 2018 at 4:51 AM
    Ctreygo
    Ctreygo New Member
    Walter
    2007 Super White 270,000 Tundra Limited Super cab
    Spray in Bed Liner, Tonneau Cover,
    What size tire would I need for 20” wheels to get the same tire/wheel ratio that you get with the 17”’s
  18. Jul 4, 2018 at 4:54 AM
    37"..back in the day with 2 to 1 ratio.....40"
  19. Jul 4, 2018 at 5:05 AM
    Ctreygo
    Ctreygo New Member
    Walter
    Wow I didn’t think I’d get a response that quick. I’m starting with a stock 07’ Tundra Crewmax. Would I need a lift for those?
  20. Jul 4, 2018 at 5:08 AM
    Ctreygo
    Ctreygo New Member
    Walter
    I saw a plate you could get welded on to make your tires not rub but I want to lift it some but I drive around 100 interstate miles a day and don’t want to wreck the way it drives.
  21. Jul 4, 2018 at 5:13 AM
    I'm running 18" with 34.5" tires and have 2.5" OME coil overs. 17" rims get you to the ideal "off-road" ratio with 35" inch tires. 20" rims changes everything if you want that "off-road" ratio. Especially with your wallet. Tires become super pricey. Serious clearance issues without substantial lift. I believe there are a coupe guys here doing that.
  22. Jul 4, 2018 at 5:16 AM
    Cab mount chop plate required for sure with 35" and up. Wheel offset needs to be considered too.
  23. Jul 4, 2018 at 5:24 AM
    Ctreygo
    Ctreygo New Member
    Walter
    Sounds like I should take the stock 20’s off and go back with the set up you have. Does it drive considerably different?
  24. Jul 4, 2018 at 5:26 AM
    Ctreygo
    Ctreygo New Member
    Walter
    I want to get enough lift so I can put on the Amped automatic step. Do you think the 2.5 you have would work for me?
  25. Jul 4, 2018 at 5:33 AM
    Go with 17". I would. My 18" drives fine. Tires a bit heavy affecting gas mileage but I don't care about that at all.
  26. Jul 4, 2018 at 5:37 AM
    Depends on what your off roading habits are I guess. My OME setup would work for you but check out the Eibach setup that ToyTec sells. Call and ask for David..
  27. Jul 4, 2018 at 5:41 AM
    Ctreygo
    Ctreygo New Member
    Walter
    Yeh I’m not so much worried about the mpg. Ok so I’ll go with 17”s And your saying I can get a 35” tire? And that set up is reasonably priced? Which suspension would you do? I have to drive a dirt road everyday that’s like 4 miles each way so I’m hoping to improve the drive on it so it doesn’t rattle my teeth once I get up to around 40 mph.
  28. Jul 4, 2018 at 6:15 AM
    I really like my OME setup. Got that from ToyTec. The Eibach is more affordable. I have an "add a leaf" out back with ToyTec shackles. There are several sizes of tires available for 17" rims. Sounds like Michelin AT tires would be a great fit for you. Not sure what sizes Michelin has for 17" but you could check on Michelins' website.
  29. Jul 4, 2018 at 6:38 AM
    Michelin®
    Defender® LTX® M/S
    LT295/70R17/E 121/118R BSW
    MSPN 46315
    TUNEBCS - Toytec/Eibach Complete Front Coilovers - 3" Lift (07+ Tundra)
    Your Price: $474.99
  30. Jul 5, 2018 at 5:38 AM
    Ctreygo
    Ctreygo New Member
    Walter
    I really appreciate your help. Would I get those for the front and rear? And what do you think about air bags for ride comfort or is that best for helping with towing?
