Would this mod increase airflow for my CAI?
Discussion in 'Performance and Tuning' started by MarkBeast10, Jan 30, 2019.
  1. Jan 30, 2019 at 10:44 PM
    MarkBeast10
    MarkBeast10 [OP] New Member
    Mark
    2000 4.7l SR5
    A3215754-A2E5-4366-85F7-E404E23B979C.jpg 8CC317B6-B9BF-487C-A38D-E3099F0F925A.jpg 451EE1CA-6FDF-4F5B-8232-7591871672B6.jpg 30949DAE-2A82-47AD-BBA1-A3C5464BE3DA.jpg A07DE419-CB41-4F23-8F96-B026BA55CADD.jpg
    I added a cold air intake to my 2000 tundra 4.7l SR5, when I took out the OEM air box I removed the side air tube from the box and put it back on the side slot in the engine bay. I’m wondering what everyone here thinks if cutting the tube would allow in more air and be less restrictive. Submit a vote and/or let me know if I should cut the tube shorter or what you think.
    Darkness likes this.
  2. Jan 31, 2019 at 1:29 AM
    MarkBeast10
    Mark
    2000 4.7l SR5
    I just wanted to see if I could capture more airflow from the original side compartment hole. What do you think about modding the OEM box and putting back in with the CAI? Is there anyway to get more airflow? I noticed someone put a mod pipe that goes to the front of the grille, might do that too.
    OR18TRD likes this.
  3. Jan 31, 2019 at 1:30 AM
    MarkBeast10
    Mark
    2000 4.7l SR5
    And thanks for having me.. I appreciate it.
    OR18TRD likes this.
  4. Jan 31, 2019 at 1:45 AM
    MarkBeast10
    Mark
    2000 4.7l SR5
    That’s makes sense. I want to see if I can mod the OEM box with the intake setup I have. I’m going to browse around and see if anyone has combined the two yet.
    OR18TRD likes this.
  5. Jan 31, 2019 at 6:46 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Welcome!
    It would need a lot of revision. I ran that same intake tube with an airbox from a Volant intake, the box helped to decrease temps by a bit but was so close to the filter on some areas that it probably lowered flow.
    I did consider building a box out of aluminium sheet metal to shroud the filter and use rubber trim around the tube to act as a gasket. I planned to just use the top of the fender as a bottom of the box since I dont have a windshield washer reservoir, I have a big open hole there. Never got far enough down the list of "what's next" to try it.
    Out of curiosity what state are you in?
    MarkBeast10[OP] likes this.
  6. Jan 31, 2019 at 9:23 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from Sin City!
  7. Feb 5, 2019 at 4:41 AM
    MarkBeast10
    Mark
    2000 4.7l SR5
    The only way I could see the OEM box fitting with the K&N setup is if I flip the box upside down and mod it a bit. I like your idea of fabbing an aluminum sheet or maybe even 3D print a poly box if it’ll take the heat and I make enough time to put that kind of effort into this future.
    I’m out of the Lone Star State of Texas.
    Excuse my responsed delay..
    Darkness[QUOTED] likes this.
  8. Feb 5, 2019 at 4:42 AM
    MarkBeast10
    Mark
    2000 4.7l SR5
    Thanks Vegas! Great to be here..
    040Tundra[QUOTED] likes this.
  9. Feb 5, 2019 at 5:59 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you go 3d printer just remember you'll need a lid to access the filter. I'll see if I can dig up a picture of the hybrid I put together.
  10. Feb 5, 2019 at 7:20 AM
    MarkBeast10
    Mark
    2000 4.7l SR5
    Cool thanks. I’m imagining a design with a deep base and a lift out access point.
