would 285/75/18 Duratrac fit on stock 2015 TRD Pro?
Discussion in 'Wheels & Tires' started by CTundraForMe, Apr 1, 2023.
  1. Apr 1, 2023 at 9:33 PM
    CTundraForMe
    CTundraForMe [OP] New Member
    Hi, I'm looking for some good off-roading tires.
    My question is whether Duratracs will fit? I've seen threads indicating 285/75/18 fits perfectly on a Pro with the front flaps removed.
    My concern is Tiresize says these are 35.1" tire, and I think technically 285/75/18 is 34.8", which means they may not fit stock? It seems DTs are hard to find anymore, so this may be moot.
    Thanks.
    Y0TA PR0 likes this.
  2. Apr 1, 2023 at 9:57 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I think @Terndrerrr is or was running 285/75 Duratracs. Maybe he'd be able to answer that question for you :notsure:
  3. Apr 2, 2023 at 5:38 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Yep. OEM pro suspension. I got rid of the little mud flaps in front of the front wheels. That’s it.
    Lots of pics in the thread in my sig
    CTundraForMe[OP] likes this.
  4. Apr 2, 2023 at 7:16 AM
    CTundraForMe
    Awesome! TYVM!
    Most of my miles are highway currently, else I'd consider these as my main.
  5. Apr 2, 2023 at 7:47 AM
    Terndrerrr
    Music City
    6UR-FE
    They’re decent on the highway and incredible off pavement. I have 40k miles on them. Mine aren’t very loud at all. But I rotate every 3k miles. Snow rated in this size as well.
  6. Apr 4, 2023 at 4:22 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I have the same tires, I have about 35k on them. They were great at first, after about year 3 they started getting hard and aren’t very good with wet traction anymore. Still have plenty of tread though! One thing to think about is I believe they have been discontinued, at least through americas tire, so if you need a replacement you might be out of luck.
    Tripleconpanna likes this.
  7. Apr 4, 2023 at 8:16 AM
    CTundraForMe
    Yeah, I noticed they are hard to come by and DT lists them as discontinued. I may have to settle for something else.
  8. Sep 25, 2023 at 9:19 AM
    jrnightrider
    jrnightrider New Member
    2020 Black Tundra TRD PRO
    I had 295/70R18 Toyo Open Country M/Ts and then Yokohama Geolander M/Ts on my stock 2016 TRD Pro. I had to remove the front mud flaps, otherwise there was rubbing in turns. Love both tires, the Toyos slightly more than the Yokohamas, but the Toyos are several hundred $ more expensive for a new set — they look and perform almost identically.
