Worth it for road trips etc?
Discussion in 'Outdoors' started by Ragnarkov, Feb 28, 2022.
  1. Feb 28, 2022 at 3:43 PM
    Ragnarkov
    Ragnarkov [OP] New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
  2. Feb 28, 2022 at 3:46 PM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    You may need flammable placards for the truck lol. Thats a lot of extra fuel
  3. Feb 28, 2022 at 3:54 PM
    Borador
    Borador New Member
    Olive Branch, MS
    2016 Crewmax 4x4 w/1794 Interior upgrade
    I had one for my lawnmower a few years ago and it took forever to fill the tank on the mower. It was gone after one summer of using it. However, it may be a good fit for you.
  4. Feb 28, 2022 at 4:30 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Are you road tripping in rural areas with no gas stations? If you aren't in the middle of no where where gas is not available, I don't see any advantage to this.
    Sundog and omgboost like this.
  5. Feb 28, 2022 at 6:01 PM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    Not to mention 14 gallons at 6lbs per gallon = 84lbs plus the weight of the container is an extra 100lbs of weight. As others have said if you're out in the middle of nowhere then do it.
  6. Mar 8, 2022 at 9:50 AM
    kevine0001
    kevine0001 New Member
    Kevin
    I echo the comment about where you're going. If you're going to be in maybe Death Valley for more than a weekend, a 5-gal jerry can is usually enough. And even then, you can make it out unless you wheel all weekend.
  7. Mar 8, 2022 at 9:59 AM
    Outbound
    Aaron
    Northern Alberta
    He's in Canada, so distances between fuel stops can certainly be long especially if he's travelling remote for hunting/fishing/camping. I usually bring along 10 gallons of fuel minimum on my backcountry trips.
    I prefer the Scepter Military Fuel Can. They don't expand, are super durable (i've seen them used as traction aids) and with the pour spout they empty in about a minute. They're not cheap though.
  8. Mar 8, 2022 at 10:05 AM
    Link?
  9. Mar 8, 2022 at 10:12 AM
    Outbound
    Aaron
    Northern Alberta
    I don't know if they ship to the US but I get mine from here. All the accessories as well.
    https://dstactical.com/scepter/
  10. Mar 8, 2022 at 10:16 AM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    As a Costco shareholder I urge you to buy one from Costco ASAP.
  11. Mar 8, 2022 at 10:19 AM
    They don't. :( Thanks for the link, though.
    Outbound[QUOTED] likes this.
  12. Mar 8, 2022 at 10:21 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    A 6 gallon gas can was always more than enough. I switched to a 2 gallon for weight savings because I hardly used the 6 gallon to begin with. That seems like a lot but it depends on how remote you travel and stay too.
  13. Mar 8, 2022 at 10:26 AM
    Outbound
    Aaron
    Northern Alberta
    Boo hiss. Oh well, now you know where to stop when the invasion happens. :D
  14. Mar 8, 2022 at 11:40 AM
    Tractor Supply
    Wallygator and GODZILLA[QUOTED] like this.
  15. Mar 8, 2022 at 12:34 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I have 2 fuel (usually squeeze around 21 liters in each) and 1 water of these. They are simply fantastic. I actually got the olive colored cans and then swapped the diesel gaskets for regular gas.
    Zero leaks (from -40C to +40C), unbelievably durable (I have been known to use one as a step) and when connected to a good spout is super fast to empty.
  16. Mar 8, 2022 at 12:58 PM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Falken Wildpeak tires
    I use 2 Rotopax 3 gal ones when atving, can ride all weekend with extra gas at cottage & mount on machine if planning longer / overnight trips.
    If needed depending on trip I would bring them with me on the road. Never had to use them with the truck but…I get where OP is coming from depending on his trip / route plan.
    Wallygator likes this.
  17. Mar 8, 2022 at 1:05 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's a whole gas tank really, for passenger cars anyway. Might be a little more than I would consider for a road trip. A 5 gallon should get you by.
  18. Mar 8, 2022 at 1:14 PM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
  19. Mar 14, 2022 at 7:24 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Princess Auto sells them too (same brand can).
    I have been eyeing them for a while. Price dropped $20, still more than your link, but free shipping and basically lifetime warranty.
    Ordered a couple and a spout for home and truck. As you said, sometimes gas is few and far between when traveling north or south of the #1. And sometimes those remote stations are closed down.
    Wallygator and Outbound[QUOTED] like this.
  20. Mar 14, 2022 at 7:39 PM
    MoToad
    MoToad New Member
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    If you are going to the Yukon take one filled fer shure cause you'll have to sell the truck to fill up up there.
  21. Mar 14, 2022 at 7:52 PM
    Outbound
    Aaron
    Northern Alberta
    Yeah, I've seen them at PA. They won't price match though and their regular price is $25+ higher. Fortunately I have family in the Lower Wasteland so I place and order for pick up in store, my dad will go pick them up and bring them too me next time he comes up to GP.
  22. Jan 10, 2023 at 9:53 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    I want to follow up on this, how are you guys mounting them in the bed? may have to head up to Northern Ontario, and want to bring as much fuel with me as possible.
  23. Jan 10, 2023 at 10:13 AM
    mountainpete
    I have a Front Runner mount that I have used in the past, but I usually ratchet strap them at the front (cab side) of the bed. I keep it simple as I like to keep my bed usable the canopy keeps it covered from the elements.
    BravoDeltaRomeo likes this.
  24. Jan 10, 2023 at 10:23 AM
    Downytide
    GTA
    That was the thought I had, but wasn't sure if that's the right way to do it, even thought about using the spare transfer flow tank.
  25. Jan 10, 2023 at 12:59 PM
    coTony
    Tony
    Montrose, CO
    My scepters (both) would expand “but” they had fuel in them most of the time and would use them each time I went out it seemed. If I didn’t I would put what I had left in the tank of my LandCruiser tank. She could not pass anything with that straight 6 even a gas station.
    The Scepters are very good expensive gas containers that is for sure
    Black Wolf and Outbound[QUOTED] like this.
  26. Jan 10, 2023 at 1:54 PM
    I'm a bit late here. Scepter products are available on Amazon here in the US of Everywhere. Very reasonably priced I might add!
    coTony and Outbound[QUOTED] like this.
  27. Jan 10, 2023 at 2:03 PM
    mountainpete
    Not the Military fuel cans. They are illegal to sell new in the USA because they don't have any child resistance or CARB compliance.
    Outbound likes this.
  28. Jan 10, 2023 at 2:05 PM
    Outbound
    Aaron
    Northern Alberta
    Yep, the military fuel cans are very different than the ones you'll find at Home Depot, Harbor Freight or wherever else you buy fuel cans.
    mountainpete[QUOTED] likes this.
  29. Jan 10, 2023 at 4:33 PM
    Scepter is not on "my" list yet. I buy strictly NATO Wavian for my needs and a small fortune on RotoPax.
  30. Jan 10, 2023 at 4:50 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
