Working high beams, really dim lows
Discussion in '2.5 Gen Tundras (2014-2021)' started by Calebrichardson85, Oct 16, 2023.
  1. Oct 16, 2023 at 12:06 PM
    Calebrichardson85
    Calebrichardson85 [OP] New Member
    As the title says, my high beams are the usual brightness, but with the low beams I can hardly tell they are on. If you get out and look they are lit up just not a usual brightness. Btw they are led bulbs with the built in drivers from headlight revolution? Anyone have any ideas?
  2. Oct 18, 2023 at 4:46 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Sounds like you should get your battery and alternator checked out.
    Calebrichardson85[OP] likes this.
  3. Oct 18, 2023 at 5:18 AM
    Kung
    KG, VA
    If it were the OEM stuff I'd say to verify it had the recall work performed.
  4. Oct 22, 2023 at 4:34 AM
    Calebrichardson85
    Everything except the bulbs are OEM. As far as I know no work has been done to them.
  5. Oct 22, 2023 at 4:43 AM
    Does your truck have the dial in it for adjusting the beam height? If it's pointed too low it'll almost look like you just have some fog lights on. Not sure for your model year, though.
  6. Oct 22, 2023 at 4:51 AM
    Calebrichardson85
    It has the adjustment but it’s adjusted pretty high in the range
  7. Oct 22, 2023 at 4:58 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Update to the 2018+ OEM LED Headlights. No matter what you do with bulbs, you'll never know the upgrade in lighting with just bulbs. Update them and don't look back!!!
    GODZILLA likes this.
