Workflow and tools question
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, Jul 11, 2020.
  1. Jul 11, 2020 at 2:07 PM
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    So this week I’d like to accomplish three items on my 2002 4x4 AC:
    1. Bilstein 6112/5120 coil overs and shocks (already assembled) Keeping stock height at this point so clips set at #3 and #1
    2. Steering rack bushings
    3. Rotors and brake pads
    Tools I think I’ll need: sockets and wrench, torque wrench, mallet, Jack, jack stand,breaker bar, pb blast, metal punch, bottle jack to help get coil over in, something to curse into out of frustration...
    How would you approach the front end?
    Remove sway bar first?
    Jack both sides of front end up for both sets of rotors, brakes, coil overs, and bushings? Or should I leave one side for some reason that I can’t see now?
    Any reason to do one before another or completely separate?
    The problems I have seen:
    Coil overs: don’t take off uca, helper or bottle jack to get new coil over in helps.
    Rotors: no issues I have seen. Maybe soak bolts in pb blast the night before.
    Steering rack bushings: take care with the “plumbing” nearby (power steering fluid maybe??), grease everything going back in, I feel like I saw some other issue here but can’t remember?
    Thanks for all the help here. This truck is coming along and I am stoked to see the transmutation after all this is done.
  2. Jul 11, 2020 at 2:33 PM
    Azblue
    The Dirty T ( ^_^)_且
    I see two things that you forgot on your list of needed tools:
    1. Beer. Lots and lots of beer.
    2. Air conditioning. You do know it's like 1 million degrees out today?
    Joking aside, good luck. I for one know that I'm not doing a damn thing outside today, my old ass would pass out in this heat.
    ventorph, bmf4069, Darkness and 2 others like this.
  3. Jul 11, 2020 at 5:58 PM
    robabeatle
    AZ
    Haha. I’ll start tomorrow morning. I wake up around 3 am; I don’t know why but it gives some time in the morning before the oven kicks on.
    Darkness and Azblue[QUOTED] like this.
  4. Jul 11, 2020 at 6:36 PM
    Professional Hand Model
    Hand Protectors
    Brush up on Himalayan Hand Jujitsu Technique for the Steering Rack Bushings. That center bushing is a tweaker.
    Darkness, Tundra2 and robabeatle[OP] like this.
  5. Jul 11, 2020 at 7:03 PM
    robabeatle
    AZ
    Sucks cause the metal in my left radius makes my hand pretty fatigued in short order but I was a jujitsuka!
  6. Jul 11, 2020 at 8:38 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sounds like you have studied the jobs well, your plan of approach is solid. Yes, jack up both sides of the front, get the whole front in the air.
    Yes, leave the uca alone. Use a good pry bar to push the lca down while stuffing the new coilovers in, really just for the bottom mount. Get the top mount in first, then do the bottom. You have 4wd so the bolt on the bottom shock mount will go back in backwards, this is totally fine and seems to be the only option. If it has been taken off before it is probably already in there backwards.
    Brakes are straight forward. Bring a 5 gallon bucket and flip it upside down to use as a table to set your caliper on, or bring a bungee cord to hang it by the UCA.
    Coilovers aren't hard at all, honestly 2 steps harder than changing a flat tire.
    Steering rack bushings will be the faaaaawk part. Have patience, that center bolt on the rack will test you. Getting the old ones out will be stubborn, after that it isn't too bad. Some guys have done this with the truck on the ground, I found it easier in the air with the key in the ignition so I could move the tires as needed.
    Best of luck, worst case if you're beat by the heat after brakes and coilovers save the steering for next weekend.
  7. Jul 12, 2020 at 5:01 AM
    robabeatle
    AZ
    So check out these bushings.
  8. Jul 12, 2020 at 5:19 AM
    robabeatle
    AZ
    Bottom of coilover
    Darkness likes this.
  9. Jul 12, 2020 at 5:20 AM
    robabeatle
    AZ
    Hmmm could this contribute to the terrible road feel?
  10. Jul 12, 2020 at 5:22 AM
    robabeatle
    AZ
    Pads driver side
    TX-TRD1stGEN likes this.
  11. Jul 12, 2020 at 5:24 AM
    Hand Protectors
    Your truck will be handling way better after the new stuff. Looks like lots of dry rot.
    robabeatle[OP] and Tundra2 like this.
  12. Jul 12, 2020 at 6:50 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup. The sway bar bushing won't change much in feel but that beat up lower shock bushing would.
  13. Jul 12, 2020 at 7:01 AM
    robabeatle
    AZ
    The driver side brake and rotor done. Easy.
    Do new coil overs come with bushings typically?
  14. Jul 12, 2020 at 7:13 AM
    This would have been a good time to upgrade the calipers to the larger 2003 versions. And yes, should come with all new bushings.
    08TXTundra likes this.
  15. Jul 12, 2020 at 8:04 AM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    :eek2: wow, that's a nasty crack in the shock mount bracket. Wonder how that gets repaired?
  16. Jul 12, 2020 at 9:04 AM
    robabeatle
    AZ
    Rotors and brakes done. Old bushings out. Used a block of wood between the rack and frame to give support r as I pounded out the drivers side bushing. I put a socket at the end of a screwdriver to punch it out. It worked well. The middle bushing wasn’t really difficult. What do you the of the condition of the old bushings? The passenger side looks fine but the others have large depressions.
  17. Jul 12, 2020 at 9:08 AM
    robabeatle
    AZ
    The calipers are stamped 13 wl
    already!
  18. Jul 12, 2020 at 9:09 AM
    Hand Protectors
    Those look like the originals with the ribs. Steering will be better now.
  19. Jul 12, 2020 at 9:09 AM
    robabeatle
    AZ
    What crack?
  20. Jul 12, 2020 at 9:10 AM
    Hand Protectors
    Same. Went back and looked and don’t see anything.
  21. Jul 12, 2020 at 9:13 AM
    robabeatle
    AZ
    Here is the wood.
    also shoot, my torque wrench goes to only 100. I know they work best in the middle of the range as well
  22. Jul 12, 2020 at 9:25 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looks like a big crack in the lower control arm...?
    Dog likes this.
  23. Jul 12, 2020 at 9:46 AM
    robabeatle
    AZ
    No that is just some edge of a metal piece that a bump stop?? Hits. Thanks for looking out!
  24. Jul 12, 2020 at 9:48 AM
    robabeatle
    AZ
    So close to putting it back together. The rack is like a mm with getting the bolts through. I pushed, rotated around grabbed the frame a pushed with my legs, wiggled the ends. You are going back on. Why do you fight me rack?
    bmf4069 likes this.
  25. Jul 12, 2020 at 10:14 AM
    robabeatle
    AZ
    Done! Well other getting to proper torque.
    “another tool”
    “Babe I gotta get it to spec. You wanna be safe when we head to the beach, yeah?”
    thanks you guys. Man, how much would a mechanic charge for that? And it feels great knowing I did the work.
    Cheers
  26. Jul 12, 2020 at 11:25 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would guess at least $450 labor
  27. Jul 12, 2020 at 11:32 AM
    robabeatle
    AZ
    Wow, that is how I am justifying some of the tools I am buying. I get to use em again.
    MVP new tool: creeper I got off CL that was brand new for a song.
  28. Jul 13, 2020 at 1:03 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Let’s see some pics or it didn’t happen!:p Considering this same setup.
    robabeatle[OP] likes this.
  29. Jul 13, 2020 at 3:18 AM
    robabeatle
    AZ
    The suspension doesnt come in until later today, which means I will start the install tomorrow morning. Truck is sitting in the carport up on jack stands looking ghetto.
    I am sure I will post pics as I'll likely get stuck somewhere along the way!
  30. Jul 13, 2020 at 4:24 AM
    robabeatle
    AZ
    I might as well replace the sway bar bushings, yes? Or does one replace the sway bar end links as well. I ask that as most "bushing kits" that I see do not have the ones for the end links.
