Won't start after putting gas in it...
Discussion in 'General Tundra Discussion' started by liker777, Oct 1, 2020.
  1. Oct 1, 2020 at 10:11 AM
    liker777
    liker777 [OP] New Member
    Oleg
    2007 lmtd ext 4x4 5.7
    Iron bumpers
    Hi there
    I have 2007 Toyota Tundra limited 4x4. Have an issue every time I put the gas in it - problems with starting right at the gas station. I use Costco 87 gas with ethanol.
    Every time at the gas station to start it I need to do multiple attempts for about half a minute in total. At home it starts perfectly. At the gas station during the start I hear the starter rotating continuously but not starting.
    Recently I also had the engine light code of catalytic converter P0420 which is minor and most probably does not affect the problem.
    Could you please tell if anybody had the similar problems or any ideas. Appreciate any help.
  2. Oct 1, 2020 at 10:38 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Oct 1, 2020 at 12:17 PM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    Had a similar issue on a company vehicle. (Not Toyota) In both cases it was related to a sensor for the fuel system, unfortunately cannot recall the specifics as it was a company vehicle. Ended up with a brief visit to dealership and fixed under a tsb.
  4. Oct 1, 2020 at 2:43 PM
    liker777
    Oleg
    Iron bumpers
    Got it, thank you, will do!
  5. Oct 29, 2021 at 5:23 PM
    stephenisfree
    stephenisfree New Member
    2008 Toyota Tundra
    What did the issue end up being? I’ve had the same issue twice now on my 2008 Tundra. A few months ago I had the purge valve replaced and it seemed to fix it, but today I filled up at the gas station and same issue again. Acts like it wants to start but won’t. If I give it a little gas that usually does the trick and it starts up. Battery is good.
    Kelz8851 likes this.
  6. Aug 13, 2022 at 8:58 AM
    Kelz8851
    Kelz8851 New Member
    Kelly
    07 tundra 4wd 5.7
    What did the issue end up being. My tundra is doing the same thing
  7. Oct 29, 2024 at 10:17 AM
    crystalinecorruption
    crystalinecorruption New Member
    2008 DC
    Having the same issue with a 2008. Starts up if I give it some gas, but otherwise clicks. Anyone get a fix on this?
