Won't start ... 03 V8 2WD 365k mi
Discussion in '1st Gen Tundras (2000-2006)' started by JustFixIt, Jun 2, 2020.
  1. Jun 2, 2020 at 12:10 PM
    JustFixIt
    JustFixIt [OP] New Member
    Hey everyone ... Made an account to post this ... After searching and reading, thought I'd ask for help in narrowing down troubleshooting steps.
    This is my 'home depot' and 'tow shit from Sunbelt rentals' 'work on the house truck'. Bought w/ about 360k on the clock. Now has 365k. Been sitting for a few weeks because of Covid, and then we had a weird, heavy, driving rain. Tried to start the truck some days after that, and no go.
    I'm mechanically inclined, not the best with electric, but can do basic multimeter stuff.
    It is probably the battery, but battery was new when I bought truck 18 months ago, so I guess I started reading and researching... I should probably take out and try new battery. But wanted to ask here too:
    Here is what I see and have tried:
    0 volts bat dead as a doornail.
    Wouldn't jump start.
    Let charge up from jump car, bat showed 13.5V while connected to jump car.
    Still no start. Lights, clicking, and sounded like something slowly turning behind firewall (starter?).
    Disconnected jumpers. Bat showed 11.7V (dead?)
    Gave up. Went inside.
    After a few days, tried to diagnose it again ...Checked Starter relay. ... Is good .
    But battery back to 0V / dead / nothing.
    And that's what was puzzling compared to the 11.7 I had seen ... Is there a short or drain somewhere?
    Is it just a dead battery and I need to go try a new one? Or is it something else that I can check and track down?
  2. Jun 2, 2020 at 1:18 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Put a new battery in it!
  3. Jun 2, 2020 at 1:46 PM
    JustFixIt
    LOL ... Got it ... Will give that a try. Thanks for the advice!
  4. Jun 2, 2020 at 2:06 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Definitely start with the new battery. A bad battery can get in the way of jumping a car if it's really shot. Also, you can take the battery to almost any auto parts store and they'll test it for you.
  5. Jun 2, 2020 at 9:37 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Cheap batteries can die quick, especially in extreme conditions. My cheapo vatozone battery is about toast at 23 months. But I drive maybe 20 miles 1 day a week.
    MS22 likes this.
  6. Jun 2, 2020 at 10:48 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  7. Jun 2, 2020 at 11:13 PM
    Tech26
    Tech26 New Member
    David
    Seattle
    Blue 2005 Tundra DC 4WD
    I agree with other replies. Sounds like it needs a battery. Get an Interstate battery from Costco or somewhere else that has them. Interstate is a good brand. Good quality battery. Should last about 6 years or so.
    Also, if you're not using the truck at least every other week, it's a good idea to disconnect the negative battery terminal or put a little wall wart battery tender on it to keep the new battery topped up.
    bmf4069 likes this.
  8. Jun 3, 2020 at 3:41 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    +1
    Drawing a battery down is really hard on it and will enventually kill it if done repeatedly. Yours is at 0 volts -- that's extreme. You may have something going on that's causing a parasitic drain, but the only way you're going to know is to put a known good battery in the truck and keep an eye on it over the course of several days. If you have a charger, I'd recommend trying to charge the current battery. (disconnect the negative terminal to eliminate any possible drain while charging)
    bmf4069 likes this.
  9. Jun 3, 2020 at 5:43 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    GODZILLA and Tundra2 like this.
  10. Jun 3, 2020 at 7:15 AM
    tvpierce
    Maine
    Biscuits and mustard.... hmmhmmm!
    bmf4069 and Tundra2 like this.
  11. Jun 3, 2020 at 8:31 AM
    Agree with the others, probably a bad battery. When they run down, sulphur buildup occurs and ruins the battery. The electrolyte is too weak. I'm lucky to get 3-4 years out of a battery anymore, they don't make em like they used to. Other problem could be battery cable corrosion. Clean the terminals and check the cables. My negative battery cable rotted out on me. On a road trip from California to Arkansas. Had to replace it in a Subway parking lot, the factory one is run inside of a wire loom with other wires. It's still in there. I just zip tied the new one to the loom along side the old one.
    JustFixIt[OP] likes this.
  12. Jun 3, 2020 at 3:47 PM
    JustFixIt
    It was a 42 month AC Delco made in May 2018...so I was thinking that it should probably have lasted longer, as it is just about 2 years old. It was dead though. Was going to replace it for free, but got a hassle about original receipt etc, and that I'd have to wait a day for it to be delivered to the parts dept, so I just went to Costco to get one since I have a project plans this weekend and need the truck ready tomorrow afternoon.
    New Costco interstate battery and it started right up. Phew.
    So ... All good! ... although I broke a cardinal rule of auto repair, put a wrench on the manifold which promptly fell into the engine bay and lodged in the most inaccessible place on the front cross member. Managed to get it out.
    tvpierce, Dog, Rex Kramer and 4 others like this.
  13. Jun 3, 2020 at 6:24 PM
    Glad you got it running again, welcome to the forum
  14. Jun 3, 2020 at 9:21 PM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    Funny that it was such a simple fix. That’s these trucks huh?
