Won't crank in park
Discussion in '2nd Gen Tundras (2007-2013)' started by ToyNutt, Mar 12, 2015.
  1. Mar 12, 2015 at 7:25 AM
    ToyNutt
    ToyNutt [OP] New Member
    Charlie
    Austin, TX
    2012 Crewmax 5.7
    Going on one month with my new 2012 5.7 Crewmax and and having another minor issue. Occasionally when I go to start the truck, I turn the key but it doesn't crank. The dash lights up as if it will start but nothing happens. I discovered that taking it out of park and then putting it in park again allows it to start fine. It has happened 4 times in the past month. Anyone have this issue or heard about it? Wondering if it is possibly a parking sensor. Truck is still under warranty.
  2. Mar 12, 2015 at 8:38 AM
    If it's warrantied- take it to Toyota in hopes of them duplicating the issue.
    You can also check the voltage on your battery and alternator...that's my guess to what the issue is.
  3. Mar 12, 2015 at 9:11 AM
    Mike Tread lightly.
    south carolina
    The switch on your transmission is bad for starting... if it starts in neutral then you have a bad switch...
    T-Rex266 likes this.
  4. Mar 12, 2015 at 9:22 AM
    Now that I re-read this- that sounds right.
    If OP has to play around with the linkage as it will only start in park (as should be by default) that makes sense.
  5. Mar 12, 2015 at 9:50 AM
    Mike Tread lightly.
    south carolina
    Easy fix for the op... only other thing is the linkage is out of adjustment but not likely...
  6. Mar 12, 2015 at 3:51 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    Faulty neutral safety switch perhaps!
  7. Mar 12, 2015 at 4:00 PM
    sinevirtussinelaus
    sinevirtussinelaus New Member
    Caleb
    New England
    2014 Tundra 5.7L Silver Sky Crewmax Platinum
    LED bed lights, LED interior/exterior lights, console vault safe, line-x, tonneau cover, bed lights, Under-Seat Rear Storage from ESPtruck.com, Stealth 38" LED Hood Bulge Light Bar, Husky X-act Contour Mats, Morimoto LED Fog lights, LED Headlights
    Another option to check would be the connections to the starter. If any of them have corrosion on them it may cause this. What I didn't read was if when you turned the key as if you were going to start it, what did the truck do? This would help in diagnosis.
  8. Mar 19, 2015 at 8:54 PM
    ToyNutt
    Charlie
    Austin, TX
    2012 Crewmax 5.7
    Took it to the dealer and they didn't find anything wrong of course. Been a week without it happening, hoping it continues.
  9. Mar 20, 2015 at 6:50 AM
    I hate when they can't replicate the issue.
