Wondering if this will rub?
Discussion in 'Wheels & Tires' started by JackedNTatted, Feb 10, 2020.
  1. Feb 10, 2020 at 6:23 PM
    JackedNTatted
    JackedNTatted [OP] New Member
    Hey guys, first time posting here.
    I recently bought a base SR5 2017 tundra.
    On Wednesday I will be putting a 3.5 Rough Country Lift on it, I recently purchased wheels and tires 295/65/R20 Nitto Ridge Grapplers.
    I kinda pulled the trigger early and the guy said I may have some rubbing with 35 inch tires but im not sure, does anyone have any experience with this?
  2. Feb 10, 2020 at 6:26 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Depends on the offset and width of the wheels.
    15whtrd likes this.
  3. Feb 10, 2020 at 6:30 PM
    JackedNTatted
    They are 9 width and 12 offset
  4. Feb 10, 2020 at 6:35 PM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    I’d bet money you are atleast gonna drop mud flaps and need 1/2 bumper spacers. Atleast that’s what I had to do on my 285/65/20 tires on my stock platinum wheels with 1.25 spacers and it was also needed once I went with 20x9 +18 offset same tire.
  5. Feb 10, 2020 at 6:39 PM
    My old FN BFD's had a 12+ offset and 2.75" OME coilovers. 34.5" Cooper STT Pro's. No cab mount chop required but I'm sure you will need to, plus the flaps need to go.
  6. Feb 10, 2020 at 6:48 PM
    Hhtundra
    Hhtundra New Member
    Safest way is to do a bmc and be ready for spacers if the offset rubs, but +12 should be okay.
  7. Feb 10, 2020 at 6:53 PM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Bmc/cmc is easy, dont let a little cutting intimidate you haha. Removed the mud flaps, throw the tires on, if it runs the cab mount, chop it and roll on
  8. Feb 10, 2020 at 6:55 PM
    JackedNTatted
    How does it look after you chop it though? Or are spacers a better idea?
  9. Feb 10, 2020 at 6:58 PM
    jordan0317
    Jordan
    Martin, TN
    If you mean wheel spacers, that will only make it rub the cab mount even more. After you do the cut if you do it, you can have someone weld a filler plate in and it will look factory, there are a few companies that sell the fill plates pre cut and bent, just make your cut with it as a template and you're good. I just did mine yesterday to put my 37's on today and dont plan to put a plate on there for a bit (time and having someone make one for the cut I did)20200209_144531.jpg
  10. Feb 10, 2020 at 7:02 PM
    19TundraPlatinum
    Maryland
    I was talking about 1/2 bumper spacers to push the front bumper out further since mine rubbed in the front of the wheel well. I had no issues with bmc rub. The spacers I’m talking about wouldn’t help you on and rubbing in the rear of the wheel well.
    jordan0317 likes this.
  11. Feb 10, 2020 at 7:04 PM
    Hhtundra
    Hhtundra New Member
    Try and stay away from spacers all together.
