Wondering about beach driving (SR5 or SR5-Offroad)
Discussion in '3rd Gen Tundras (2022+)' started by mikes_groove, Feb 5, 2024.
  1. Feb 5, 2024 at 11:04 AM
    mikes_groove
    mikes_groove [OP] New Member
    Prospective Tundra buyer here. I've searched the forums but I didn't see a thread specific to the 3rd gens.
    My question is how good or not good are the 3rd gens in sand? I see some talk about concern over ground clearance for this gen. Going to OBX (Corolla/Carova) area for vacations for the coming years. Looking for any input how how these would do on stock setups.
    I am coming from a Subaru Outback. It has made the trips to the beach no issue (air down tires) but it is very close ground clearance wise. Just concerned stepping up to the Tundra if its not going to be any better or maybe even worse.
    fwiw, I have a deposit down on a 2024 Tacoma but with the rates/deals going on I could jump to a Tundra for maybe 5-7k more 'only'.
  2. Feb 5, 2024 at 11:09 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Same thing, air down your tires, you’ll be fine.
    mikes_groove[OP] and JMGmanAZ like this.
  3. Feb 5, 2024 at 11:16 AM
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    Air down. I’m not stock but saw some stock 3rd gen’s on the same day. Easy peasy
  4. Feb 5, 2024 at 11:51 AM
    mikes_groove
    From the web: 225/60R17 is my tire size on the outback with 8.7" ground clearance before airing down. I have also noticed that the 'underbody' of the outback is very flat in that there are not many things hanging down that would drag. I can tell you I could hear sand dragging at times during the drive but not a huge issue. Comparably, it is very light vs. a Tundra. I think the subaru ground clearance is true to the underside of the body.
    Tundra: seems like ~9inches stock according to the web on the SR5 so long as you don't go fast enough for the front air dam to deploy? I think on the Off-road that front air dam is not included.
    The numbers feel like maybe they indicate different things? Like is the front bumper of the SR5 really 9" or is the 9" measured from somewhere else and the front clearance is actually more?
  5. Feb 5, 2024 at 12:02 PM
    mikes_groove
    So far as I can tell, its ~11 inches. I have a 2024 TRD Offroad Longbed reserved. I think I was just a little concerned because I have seen people note that the Gen 3 Tundra's lost ground clearance vs. Gen 2. Wondering if its enough that anyone thinks it would be an actual issue. I guess my only other concern is the loss of front recover points which would make getting pulled out a little more of a pain.
  6. Feb 5, 2024 at 12:10 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Almost all pickups are limited by the rear differential. If you look at any picture online you can pretty easily tell that is the lowest point.
    I don't have one but I would be shocked if the stock bumper is lower than like 14-15" (minus the air dam if equiped and deployed). The front bumper is just about level with the center of the front hub on a 33" (265/70R18) tire
  7. Feb 5, 2024 at 12:13 PM
    mikes_groove
    Ahh! This makes sense. I was wondering if the rear diff was where that measurement would be taken from. Thanks for pointing that out. I am a truck newb and I fully admit that.
  8. Feb 5, 2024 at 12:26 PM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I did fine in soft beach sand with my 2 gen Tacoma... it had the same width tires (265) as Tundra OR OEM tires. Tundra is a lot heavier so IDK how it would do in the sand. It might try to sink in more.
    mikes_groove[OP] likes this.
  9. Feb 5, 2024 at 12:26 PM
    xc_tc
    xc_tc New Member
    I wouldn’t worry about clearance. You would only get stuck if you sink in the sand to the frame. That’s really unlikely unless you get into one of the dunes with deep, loose sand.
    raylo and mikes_groove[OP] like this.
  10. Feb 5, 2024 at 12:36 PM
    mikes_groove
    Yeah, thats one reason I wanted to post to the board and just see what people's experiences had been like. The OBX beaches have notoriously soft areas and also a bunch of idiots who chew up the area real bad and make it even worse then it normally would be. There are facebook groups just posting pics of people stuck. I'm not trying to end up in their facebook group in my new truck LOL.
    Retired...finally likes this.
  11. Feb 5, 2024 at 12:39 PM
    raylo
    Frederick, MD
    That's where I took the Tacoma and it handled the soft deep stuff without airing down. Personally, I would not be comfortable taking my Tundra to those same places in stock form. You might pull it off... but maybe not... and that would get $$$. If you put on some 285s or 295s I think you'd be good to go.
  12. Feb 5, 2024 at 1:26 PM
    mikes_groove
    Yeah, in my experience, its a chain reaction that occurs where one of the vehicles in a line of traffic get stuck and then people try to maneuver around the stuck vehicle(s) and that is what gets you into the softer areas. If you can manage to just not end up stopped things are fine.
    raylo[QUOTED] likes this.
  13. Feb 5, 2024 at 2:29 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Took my 2007 CM to Carova last summer. Running Cooper AT3 275/55/20 . Never aired down, didn't have any problems at all. Had it in basic 4hi. The stupid horse tours drive all over the beach and think nothing of just coming to a dead stop, so watch for them.
  14. Feb 5, 2024 at 2:37 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Lol, airing down is a good thing. Four people in this picture didn't figure that out. IMG_8637.jpg
    dondino likes this.
  15. Feb 5, 2024 at 6:16 PM
    mikes_groove
    It is crazy there are signs every couple hundred feet for airing down and 'free air' even to air back up yet so many people drive right past it. Maybe I am over-worrying about it.
    pwpblue[QUOTED] and dondino like this.
  16. Feb 6, 2024 at 5:50 AM
    raylo
    Frederick, MD
    And half of those times are trying to get around people who stop where they shouldn't to belatedly air down.
  17. Feb 6, 2024 at 6:26 AM
    pwpblue
    Greensburg,PA
    Last time I was at the OBX 4x4 beach 7 yrs ago. You had to air down and I found under 15 psi was the best for me.
    You can see how soft the sand was and without airing down you'd never be able to turn the wheel and get out. Kinda like a slot car if that make sense?
  18. Feb 6, 2024 at 6:44 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
  19. Feb 6, 2024 at 9:30 AM
    mikes_groove
    Yep thats exactly what I remember. This picture plus a hundred vehicles trying to manage that at the same time. Also @pwpblue I'm your neighbor. I'm just a few miles south of Pittsburgh :)
    pwpblue[QUOTED] likes this.
  20. Feb 6, 2024 at 11:08 AM
    pwpblue
    Greensburg,PA
    Cool!
    Hi neighbor :wave:
    I'll find a pic when we went on the 4th of July!
    Two Honda passports were drawing on the sand.
    Screenshot_20240206_140626_Gallery.jpg Screenshot_20240206_140603_Gallery.jpg
  21. Feb 6, 2024 at 11:20 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I drove the beaches in OR and WA plenty of times in a 2WD TRD OR Tacoma. Never aired down. Never got stuck. Used the rear locker once in some deeper stuff just in case. No issue. ‘23 Tundra has been on the beach in WA 3x now. Never out of 2WD and with the cheesy Fake Falkens at 40psi. Dont worry about a thing.
  22. Feb 6, 2024 at 11:33 AM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
  23. Feb 6, 2024 at 11:37 AM
    PNW Tundra Mike
    Back in So Cal
    Agree, when needed
  24. Feb 6, 2024 at 11:40 AM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    Sorta comparing apples and oranges here. Sand type and firmness varies drastically beach by beach, by temp, by region, and by how many people have been driving on it. In winter when the beaches are deserted, I have driven on in both Delaware and Assateague with fully inflated tires and in 2WD in both my Tacoma and my Tundra, with only a hint of struggle at the entrances and exits. Summer out here is a different story, and fully inflated tires/2WD is a recipe for a long day. I can switch it into 2WD if I desperately want to once I’m moving on the hardpack, but getting going is a different story. Better to just leave it in 4Hi and rock it out for my taste.
    pwpblue and mikes_groove[OP] like this.
  25. Feb 6, 2024 at 3:37 PM
    PNW Tundra Mike
    Back in So Cal
    Agree. Never went into the dunes with 2W and aired up. Have lots of sand experience in an 80’s Jeep CJ where 15psi and 4wd was still a battle at times.
  26. Feb 6, 2024 at 3:55 PM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    I was down in OBX this summer a little further down than you. We were in Buxton and Hatteras with my 2020 tundra limited. It’s not difficult. Just remember to air down and if you start to sink stop hitting the gas!
    mikes_groove[OP] and pwpblue like this.
  27. Apr 15, 2024 at 1:12 PM
    mikes_groove
    I am looking at a 2024 Offroad it has the 20" premium wheel option. Any thoughts on how much worse the experience will be with the 20" wheels? When I looked at it I couldn't figure out why a offroad trim would offer 20" wheels considering you probably wouldn't want reduced sidewall in offroad situations. Seems like airing down a 20" tire isn't gonna beb very effective.
  28. Apr 15, 2024 at 1:40 PM
    pwpblue
    Greensburg,PA
    It does make a difference. My past f150 with 20's aired down to 12/15 psi and was the one pulling other folks out that did not air down. I'm sure other off road excursions the 18's will shine but the 20's do fine in the sand just air down.
    PNW Tundra Mike likes this.
  29. Apr 15, 2024 at 5:47 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    Never driven on the beach. Prohibited here. But out of curiosity. Wouldn’t the sand increase the chances of rust. I would imagine sand gets everywhere. Will a good pressure wash mitigate the potential damage? I have always hosed down my trucks after launching the boat (saltwater) but still, I have always gotten a bit of rust. At least on the hitch even after washing.
  30. Apr 15, 2024 at 6:20 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Putting 20’s on an OR is one of those Toyota conundrums actual off-roaders will never understand.
    Tundrastruck91 and Nm6300'asl like this.
