Wiring Tail Lights
Discussion in 'Lighting' started by Jeff 2019 Tundra, Sep 13, 2020.
  1. Sep 13, 2020 at 5:41 AM
    Jeff 2019 Tundra
    Jeff 2019 Tundra [OP] New Member
    Need some help wiring all this. Where did you connect the yellow turn signal wires? Where did you run the red and black to? Do you have pictures of your wiring set up? Where you ran all the wires under the truck?
  2. Sep 13, 2020 at 5:41 AM
    Jeff 2019 Tundra
  3. Sep 13, 2020 at 5:56 AM
    Welcome from NY.
    What taillights are those?
  4. Sep 13, 2020 at 6:18 AM
    Jeff 2019 Tundra
    Custom retrofitted spyders with RBG LED
  5. Sep 13, 2020 at 6:28 AM
    Didn't come with instructions?
  6. Sep 13, 2020 at 6:56 AM
    Jeff 2019 Tundra
    No nothing. All the YouTube videos I have found are just plug and play.
  7. Sep 18, 2020 at 6:16 AM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    I think I would return and look for a different set of lights. What I see there looks to be spliced into your existing wires along with power from your battery. I would not start cutting up my OEM wiring and start a whole new set of headaches. If there was a way to put a T in the 7 pin trailer harness maybe but not sure what to do with the OEM wires if you could.
