Wiring Questions
Discussion in 'Audio & Video' started by Foxxer8-7, Oct 27, 2024.
  1. Oct 27, 2024 at 12:47 PM
    Foxxer8-7
    Foxxer8-7 [OP] New Member
    2021 Grey Tundra TRD
    I'm getting ready to install some subs (MTX terminators) in my Tundra. Unfortunately, my head unit is the stock JBL, so there are no RCA outputs. I made wiring plans to use a LOC and splice off the audio signal from the stock rear subs, by my AMP (Rockville dB12) has speaker wire inputs in the back.
    My question is: Do I even need the LOC? Can I use the stock sub wires and just feed them into the amp? I am a complete audio newbie so any help is appreciated
  2. Oct 27, 2024 at 1:00 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    I don't see that your amp accepts speaker-level inputs.
    I think you'll need an LOC.
    Rockville dB12 2000 Watt Peak/500w CEA rated RMS Mono 2 Ohm Amplifier Car Amp
    I see RCA inputs and bypass outputs and then your sub speaker outputs.
    I don't see any kind of switch to select RCA or speaker level for the input.
    As far as selecting a signal, I'd use the rear speakers to tap into for a cleaner signal and then use the amp's low pass crossover..
    I wouldn't trust the JBL amp output to the subs.
    Good luck..
  3. Oct 27, 2024 at 1:04 PM
    Foxxer8-7
    In all honesty, I probably read the description wrong. I'll take the advice on the rear speakers and send those to the LOC instead.
