Wiring off road Fog lights
Discussion in '1st Gen Tundras (2000-2006)' started by Ccwave, Feb 24, 2020.
  1. Feb 24, 2020 at 10:26 PM
    Ccwave
    Ccwave [OP] New Member
    Casey
    Nevada
    2006 Toyota Tundra Limited Double Cab 4WD
    Frontier Grille guard, Tool Box
    Gonna buy some fog lights from tractor supply and mount them to my frontier grille guard and wire them to where the switch where the inverter would be. wondering if anyone has any tips for getting it through the fire wall I'll take pictures before and after I sort it out
  2. Feb 24, 2020 at 10:29 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Open your hood and look at the firewall between the brake booster and the driver side fender. You'll see a rubber grommet, great place to poke a hole for wires to pass.
  3. Feb 24, 2020 at 10:31 PM
    Ccwave
    Casey
    Nevada
    Thanks I'll start there
  4. Feb 24, 2020 at 11:01 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  5. Feb 24, 2020 at 11:13 PM
    Matthewkort
    Matthewkort New Member
    Y not get a new connector and wire to your fog switch! That’s what I did myself.
    Ccwave[OP] likes this.
  6. Feb 25, 2020 at 12:11 PM
    Ccwave
    Casey
    Nevada
    I have the double cab with the rear window switch/button unless you're talking about the switch on the the steering wheel
  7. Feb 25, 2020 at 12:44 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Do you have a fog light switch on the turn signal stalk?
  8. Feb 25, 2020 at 12:56 PM
    Ccwave
    Casey
    Nevada
    Yeah just making sure I saw a video where he had a separate button near the mirror adjustment switch
  9. Feb 25, 2020 at 7:19 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    There is also a grommet under the driver and passenger floorboard. I’ve used that spot many of times for accessories as well as the one on the firewall.
    Fish tape is helpful as well.
    1lowlife and KarmaKannon like this.
  10. Feb 25, 2020 at 7:34 PM
    KarmaKannon
    Utah
    Some junk
    I think some of the older first gens had the switch on the dash under the gauge cluster and I think at least some of those had the mirror adjuster on the door panel (the proper place in my opinion). The 05 and 06 I believe are on the stalk. Not sure if there's variation between those by model, but the 05/06 seem pretty consistent on features.
  11. Feb 25, 2020 at 9:50 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Used that one for my Amp steps and my bed LEDS...
    But be careful on I think the driver's side.
    The fuel lines run right underneath it..
  12. Feb 27, 2020 at 12:04 AM
    Matthewkort
    Haha shoot ignore my ignorance. I thought u are using these as fog lights, not aux lights so I was referring to just wiring it in where the oem fogs connect. But if it’s on its own switch... just go they the boot where the oem wires go. Orrrrr you can pick up one of the wireless switch panels.. auto zone sells one called blazer and then there is the trigger versions. Send me a pm and we can talk options and such.
