Wiring LED lights in a canopy
Discussion in 'Lighting' started by Baller, Sep 20, 2018.
  1. Sep 20, 2018 at 4:05 PM
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
    Looking for advice. I'd like to add some LED lights to the interior of my canopy. I'm not thinking it should be too hard, just need to find a source of constant power. Anyone have any experience doing this?
  2. Sep 20, 2018 at 7:39 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Or just go straight to the battery with inline fuse.
  3. Oct 9, 2018 at 5:36 PM
    Baller
    '05 Tundra SR5 DC
    My guess is tap the red wire, right? Those other taps were done by the previous owner.
  4. Oct 11, 2018 at 8:39 AM
    Baller
    '05 Tundra SR5 DC
    NewImprovedRon likes this.
  5. Oct 13, 2018 at 11:12 PM
    Baller
    '05 Tundra SR5 DC
    Got everything wired up and looking good, flipped the switch and nothing. Get out the volt meter and tested the plug and nothing. I checked the fuse under the hood and it was spent. I replaced the 30A trailer charge fuse and still nothing. I'm running out of ideas. Anyone have something I should be looking into or trying to track down? What's the next on the list at things I need to confirm as working? Thanks for any help you can provide.
  6. Oct 14, 2018 at 12:09 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sounds to me like a short. I don't know where you grabbed power from but that's where I'm guessing your problem is. A faulty ground, in my experience, doesn't usually blow fuses. (Faulty being not a good ground)
    Personally, I'd pull power from an added accessory fuse block like a Blue Sea. But if this is the only accessory you intend to add then a power wire straight off the battery with an inline fuse should be OK. This way you're sure your power supply is good.
    https://www.amazon.com/s/?ie=UTF8&k...id=kwd-298453191268&ref=pd_sl_octztcma3_e_p38
  7. Oct 14, 2018 at 7:48 AM
    Baller
    '05 Tundra SR5 DC
    Adding a fuse block would probably be the best solution to getting power to my lights but, that won't solve my problem of no power getting to my trailer plug. For clarity, I took power off the charging wire going into the plug and that's how I ended up going down this rabbit hole.
    831Tun[QUOTED] likes this.
  8. Oct 14, 2018 at 2:51 PM
    Professional Hand Model
    Hand Protectors
    Reverse your steps and fix what you messed up. Then start fresh with what 813Tun says.
    831Tun likes this.
  9. Oct 14, 2018 at 2:59 PM
    Baller
    '05 Tundra SR5 DC
    The truck is new-ish to me and I'm as certain as I can be that the problem existed prior to me tapping the wire last night.
  10. Oct 14, 2018 at 3:04 PM
    Hand Protectors
    Ok. Start fishing for cut wires and splices. Painstaking work, but better than paying someone.
  11. Oct 14, 2018 at 3:07 PM
    Baller
    '05 Tundra SR5 DC
    I'm not entirely certain this is always true....
    I like to work on my vehicles and I find very little of it intimidating or not worth it but, electrical problems are something I want little to nothing to do with.
  12. Oct 15, 2018 at 4:27 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Have you tried with the key on? Wiring diagram looks like it's only active when the key is switched on. You could pull the relay and jump the terminals to provide a constant voltage.
  13. Oct 15, 2018 at 8:28 AM
    Baller
    '05 Tundra SR5 DC
    I haven't. I'll have to try this out. Thanks for the info. You'd make my day if that's all it is. I've been stewing over having to track down an electrical ground.
  14. Oct 15, 2018 at 2:32 PM
    Baller
    '05 Tundra SR5 DC
    Ran out over lunch to give this a try and got nothing. I was hoping for an easy fix. :( Truck on and nothing lit up. Checked the fuse and it's still good. If there was a short, wouldn't the fuse pop as soon as I turned the truck on and relay closed the circuit?
  15. Oct 15, 2018 at 3:24 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    It's possible the relay is bad.
  16. Oct 15, 2018 at 3:27 PM
    Baller
    '05 Tundra SR5 DC
    Thanks, that'll be the next thing I'll look into. I'd be as happy as a pig in slop if it were a simple plug and play item like a relay. Wish me luck.
  17. Oct 15, 2018 at 10:36 PM
    Baller
    '05 Tundra SR5 DC
    Tested the relay and it worked as it should.
    I got sick of it and wired the lights directly to the battery and now they work like a charm. While I ran the wire, I also tucked up and made tidy some other added wiring, like the backup camera, so that made me feel better.
