Wiring harness for p3
Discussion in 'Towing & Hauling' started by Halfjap, Jan 9, 2017.
  1. Jan 9, 2017 at 2:47 PM
    Halfjap
    Halfjap [OP] New Member
    Reno, NV
    2015 White Tundra Crewmax
    Hopefully some one can help me on this, I just got a new tekonsha p3 brake controller and an ESP mount for my 2015 crewmax. Does anyone know what wiring harness I need to get? I thought it was the 3040, but it's not even close. IMG_4019.jpgAny help is much appreciated.
  2. Jan 9, 2017 at 6:43 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    You need the 3017P. 3040 is for an older truck.
    MotoTundra likes this.
  3. Jan 9, 2017 at 6:54 PM
    Cfincke
    San Antonio
    I have a 2014 tundra and just installed the P3 controller last weekend, I used the 3040P cable without issue. If I recall, Tekonsha website also lists the 3040P when you search for 2014+ tundra.
    The connector the 3040 cable plugs into is behind the panel to the left of the emergency brake. In my truck, the connector was taped to another connector. It was up above most the other cables, towards the firewall.
    Hope that helps.
  4. Jan 9, 2017 at 7:12 PM
    Halfjap
    Reno, NV
    Thank you. I did some more research and that is what I came up with as well. Now the waiting begins.....again.
  5. Jan 9, 2017 at 7:12 PM
    Cfincke
    San Antonio
    @CM-LENNY is correct, the 3017P is the correct cable for a 2015. The 3040P is for 2003-2014 tundra
    MotoTundra and Halfjap[OP] like this.
  6. Jul 21, 2020 at 5:05 PM
    Up The Irons
    Up The Irons New Member
