Wiring/fuse help
Discussion in 'General Tundra Discussion' started by Dryflyhunt, Jul 5, 2019.
  1. Jul 5, 2019 at 10:05 AM
    Dryflyhunt
    Dryflyhunt [OP] New Member
    2016 Black Tundra Crewmax Limited TRD
    Tint, tonneau, chrome to black
    Recently purchased the attached aftermarket grill and would like to be prepared for when it arrives. Can someone please advise in the easiest terms to comprehend, how to sync the 3 Amber lights with the daytime running amber lights on my 2016 CM? TIA.
  2. Jul 5, 2019 at 12:36 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    There’s a few write ups on this. They usually involve an add-a fuse, which turns an existing fuse, say your driving lights, into 2 fuses so you can power an additional item with them (your grill). You can either tap into a fuse in your engine block or footwell fuse box inside cab. It’s likely much easier to tap into the fuse block inside the engine compartment so you don’t have to go thru firewall. There’s 3 different size add-a-fuses, micro, mini and regular, make sure you know which size...here’s a write up that walks you thru doing this...https://www.tundras.com/threads/mikes-diy-raptor-style-led-mod-thread.3764/
  3. Jul 5, 2019 at 12:41 PM
    Dryflyhunt
    Awesome, thanks so much man. I really appreciate you taking the time to reply.
  4. Jul 5, 2019 at 12:42 PM
    HellBent
    HellBent Breaker of Things
    Brayden
    2017 SR5 TSS 5.7
    Installed this grill on my 17 TSS, like it a lot. Everything lined up perfectly and fit/finish/composition was much better than expected, especially for the price.
    I didn't want to run a lead into the fuse box, so I wired mine using https://www.amazon.com/gp/product/B07114RK67/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 from Amazon, its nice in that it allows to splice both both wires from the source to both wires of the lead in a single, weatherproof press-on connector. The LED's don't draw enough amps in comparison to the DRL's for the ECU to even notice.
    I used the leads from the driver's side DRL right behind the bulb as it feeds into the connector. It's easy to get to and allows a quick connect (See Photos). If you use the two wires shown in my photo, then your grill lights will flash in time with the driver's side turn signal (this was before I corrected it). Use the White/Black and the Purple wires to achieve a solid-on anytime the DRLs are active.
    ***HINT : Because we tend to do wiring with the vehicle off (and I almost always set the park brake when I kill it), BE SURE TO RELEASE THE BRAKE prior to cranking the truck to test your wiring. If the brake is set when the key is turned, it deactivates the DRLs until the brake is released. This little tidbit had me thinking I was on a bad connection or wrong wire, leading me to recrimp and try different wire pairs several time unnecessarily. Turns out I was right the first time.
    Dryflyhunt[OP] and Jrharvey02 like this.
  5. Jul 5, 2019 at 12:46 PM
    Jrharvey02
    This is a real easy way to do it too, tapping into the two wires that power the tiny amber bulb on the very top corner of headlights. Not a lot of wire to work with, which makes tapping into a bit more difficult, but easy in itself...this method usually doesn’t involve fusing your new stuff, which isn’t a huge deal when you’re adding 3 led lights that pull very little amps
    Dryflyhunt[OP] likes this.
  6. Jul 5, 2019 at 12:50 PM
    Jrharvey02
    You should also look into color matching that grill...is yours a black truck? If so, I color matched my identical grille with duplicolor 202 black Toyota color match from auto store. After 3 coats I covered with a clear enamel recommended by ace hardware. It came out pretty darn good. I only wish I would have taken time to wet sand but it looks good enough.
  7. Jul 5, 2019 at 12:54 PM
    HellBent
    Brayden
    2017 SR5 TSS 5.7
    Mine is MGM. I initially intended to color match it, but after test installing it, it looked really good in black up against the black bumper and lights. The camera makes it look a little more jarring, but to the eye its a nice contrast to the rest of the front end, especially after replacing the chrome bulge with the color-matched bulge in the photo
    I didn't even elect to add any sort of emblem after the fact.. Thinking of adding some hideaway strobes behind the honeycomb, though.
  8. Jul 7, 2019 at 7:32 AM
    Dryflyhunt
    Thanks guys, super helpful. Have already purchased the wire connectors so I’ll tackle it when the grill arrives. So, do I ONLY use the white/black and purple wires in the connector, and leave the red out, to achieve solid amber lights? Thanks.
  9. Jul 7, 2019 at 8:07 AM
    Jrharvey02
    I’m a little confused about the question, your grille led lights will come with a connector that has a red (+) and black (-) wire on the end , you need to connect the red wire to the positive wire going into the headlight bulb or add-a-fuse, the black wire either gets connected to the negative wire going to the headlight bulb or you can just ground to chassis if going the add-a-fuse route. Not sure which “red” wire you’re contemplating leaving out.
  10. Jul 7, 2019 at 8:14 AM
    Dryflyhunt
    Sorry, I was referring to Hellbent’s comment in regards to the wires he used. I don’t use this forum as much as I should, so I’m not sure how to respond to a specific post. I am choosing to go the snap on wire connector route as opposed to the add a fuse route. He mentioned to use the black/white and purple wire to achieve solid light with the DRLs.
  11. Jul 7, 2019 at 8:42 AM
    Jrharvey02
    Ah, okay, I’ll let him respond. To respond to a specific post, such as I am doing here, hit the “quote” button at the bottom of the post you are responding to, then type your response
  12. Jul 7, 2019 at 10:48 AM
    Dryflyhunt
    Much appreciated, thank you!
  13. Jul 7, 2019 at 10:49 AM
    Dryflyhunt
    So, is the red wire left out of the connector? The black/white in one side and the purple next to it? Thank you!
  14. Jul 15, 2019 at 5:56 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    Not sure how he fixed this. But the white/black is a ground wire to that bulb and the purple wire is a parking lot wire. Purple won’t have power unless you turn on your lights (at least on a 16’ with halogen drl’s) wiring is different if there are led drl’s from factory
  15. Jul 15, 2019 at 5:58 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    If you are powering. Use either purple or the red. DO NOT connect purple with the white and black wire. Why/bk is connected to ground. Always use a multimeter to verify first.
  16. Feb 26, 2021 at 8:34 AM
    pjmdaddy
    pjmdaddy New Member
    Patrick
    17 Crewmax
    I have this same grill and one of the lights is getting really dim. Was curious if any of you know or have replaced these lights? The closest I have found for replacement lights is the Ford Raptor replacment lights like this one - https://www.amazon.com/gp/product/B...title_srh_1?ie=UTF8&psc=1&smid=A1LGDXCZMXB2CW There are a lot of reviews that say the wiring is backwards for them too, which causes more confusion towards purchasing.
    Have any of you had luck with replacing the lights on these grills?
  17. Feb 1, 2023 at 5:49 AM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am going to revive this old thread in hopes of clarifying what I want to do and to not start a new one. Hopefully some of you are still around here.
    If I want the lights to be on with the DRL's then I need to use the purple wire as the + and the wt/blk as the - ?
    This post confused me
    "If you are powering. Use either purple or the red. DO NOT connect purple with the white and black wire. Why/bk is connected to ground. Always use a multimeter to verify first".
  18. Feb 1, 2023 at 6:47 AM
    @RainMan_PNW or @iHacker
  19. Feb 1, 2023 at 6:50 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Did your truck come with halogen or LED lights? The DRL function and wiring changed in 2018+ trucks.
  20. Feb 1, 2023 at 6:52 AM
    Now that I'm thinking about it, look up YotaLeds. I think that those tie into the DRL's. They have harness and switch kits too.
  21. Feb 1, 2023 at 6:59 AM
    IowaGuy
    IowaGuy New Member
    In Process
    I have the halogen with the DRLs in a strip below them. The DRLs look like LED but I dont think they are.
  22. Feb 1, 2023 at 7:03 AM
    Those are led.
  23. Feb 1, 2023 at 8:55 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    So you want the grille lights on whenever the ignition is on?
    So you have the white LED strip on the bottom of the headlight?
    The problem with using the DRL to power the grille lights is they have a high and low.
    High with the parking/headlight off, low with the parking/headlights on.
    I guess you could tap into both but I don't know if that would cause conflict.
    That is why there are 2 leads + the ground wire.
    The diagrams are a little confusing.
    Some headlights had halogen headlight bulbs and halogen DRL.
    Some had halogen headlight bulbs and lower LED strips, which I think you have.
    Some had LED headlights and upper and lower LED DRL strips.
    *36 is the Halogen type with the separate halogen DRL/turn signal
    The violet wire is low, connected to the tail lights (parking light) circuit pin 2
    And the red wire being high, connected to the IGN pin 1
    black/white ground pin 3
    *37 is the LED type what I think you have.
    Same colors, violet low pin 6 and red high pin 5 black/white ground pin 5
    upload_2023-2-1_10-42-44.jpgupload_2023-2-1_10-30-15.jpgupload_2023-2-1_10-34-33.jpg upload_2023-2-1_10-33-57.jpgupload_2023-2-1_10-34-57.jpg
    I hope this makes sense...
    I connected my grille lights to the parking light circuit of the headlight.
    They only come on with the parking/headlights, I didn't want them on during the day.
    I retained my amber DRLs on my OEM LED headlights for day time, the dim strips come with the parking headlights.
    IowaGuy[QUOTED] likes this.
  24. Feb 1, 2023 at 9:14 AM
    IowaGuy
    IowaGuy New Member
    In Process
    So I am wondering now if I put a relay in there and used both the purple and red DRL wires to each trigger it if would work and not cause issues. Another idea would be to put a one-way diode in line so that it could not feed back to the other high/low.
    I might just use a tap a fuse to put them on the tail light power as others have done, or a tap a fuse to a IGN on circuit.
    1lowlife likes this.
  25. Feb 1, 2023 at 9:50 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    And starts a new thread anyway...
    RainMan_PNW and FrenchToasty like this.
  26. Feb 1, 2023 at 10:04 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I guess the ECU determines if the DRL is on hi or lo, depending on the taillight circuit being on.
    I pretty much tapped into the 'taillight' circuit of the headlight parking lights.
    I used posi-taps and put a small inline fuse as well as a Deutsch connector if I need to pull the grille.
    I shrink-wrapped the posi-taps, although that area really doesn't get much weather/moisture.
    ED9943DE-EF87-495C-B7D9-2D0618D68B24_zps_84d5ac37a38531fa0c15f8880a3edfe145b48c00.jpg
    51AA14B2-FCB4-48B4-ACE9-C05B99AC172E_zps_3216112bc4b49f1a9cafbd4fc2ed9f5d853356a3.jpg F27CB0DF-A4EC-4639-AC7D-1DA96A1B1E8C_zps_ac396edf69bbddb04d8bdeb0969d960796e98a65.jpg
    2AC76BE3-391B-41D3-A70A-E8FC2829176D_zps_e572e0f24156aa20ac37f373090c3865fa2b28be.jpg 5F225999-563B-4406-85F4-7844858A0198_zps_f5708ba39e084ec06f8781bc55d4d9c4a2819a22.jpg
    I used my own LEDs on a TRD Pro grille
    FDB3B258-E8CE-43B8-8075-DDD2CAF90E48_zps_0a70d89881f84d37669a78aa973c2705361e4bbd.jpg ABEC7A28-35BA-4A33-BD35-80B3FA3E8A6F_zps_9372486f3d00551c077e1551e2b239e4ff1d3c59.jpg
    286637AF-C3EE-4A0D-873E-1877CC890D98_zps_1a72a6ad33a8cb2ffa8bae17f736752bbc88a56a.jpg 0F4F35C4-4907-42C4-AF61-001535EC9804_zps_e6beecdf67be75d32f10a79d534e8b8ca67f5948.jpg
    Good luck...
    IowaGuy likes this.
  27. Feb 1, 2023 at 10:26 AM
    IowaGuy
    IowaGuy New Member
    In Process
    Please show me exactly where that hurt you. If you dont like a thread then dont read it. I thought I would get some more answers from people by asking about my specific question.
    RainMan_PNW and 1lowlife like this.
  28. Feb 1, 2023 at 10:43 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Doesn't hurt me in the least. I was just poking fun at you creating yet another thread. I know the internet and forums can be hard, even for a government IT employee.
  29. Feb 1, 2023 at 5:05 PM
    IowaGuy
    IowaGuy New Member
    In Process
    I think this might be one solution. High and low DRL inputs into this diode and the out side to the grille lights. Whatever side is lit on the DRL's would feed the grille lights but they would not feed back into one another.
