Wiring from Hood Mounted Lights into Cab?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 80392, Jul 15, 2022.
  1. Jul 15, 2022 at 2:57 PM
    80392 [OP] 2021 Tundra Work Truck Package
    Barry
    OK, folks, here's my plan: Mount these lights on the hood of my 2021 Tundra, each with a magnetic mount...
    1. Nilight ZH001 20Inch 126W Spot Flood Combo Led Off Road Led Light Bar 2PCS 18w 4Inch Flood LED Pods With 16AWG Wiring Harness Kit https://www.amazon.com/dp/B06XP2J1G1/
    2. Nilight 90042B 2PCS Magnetic Base LED Light Bar Mounting Brackets, Powerful Sucker Holder for Bottom-Mounted Offroad LED Work Light Mounting on Hood https://www.amazon.com/dp/B0831MG3CM/
    I believe the lights and mounts will all fit together OK. I'd like advice on best/simplest way to wire to battery, and to get on/off switch into the cab.
    Did I mention I have zero experience with wiring anything on any vehicle? :)
    But that's the amazing journey I have with my 2021 Tundra... I am not letting my lack of experience stop me! And my other projects seem to have come together AOK so far (see bottom).
    So, any advice is welcome and please, assume I know nothing (because that's what I assume). Thanks! BMcC
    PHOTOS of my 2021 Tundra Work Truck Package https://photos.app.goo.gl/E6aLXQsnbtLG6jiv5
  2. Jul 15, 2022 at 3:43 PM
    ConcordCarlos
    ConcordCarlos New Member
    Carlos
    2021 Tundra SR5
    Looks like the light kit comes with a pre assembled wiring harness.
    I would switch out the switch though, and use one that fits into one of the blank spaces left or right of your steering wheel.
    There is a “nub” on the firewall grommet that can be clipped to run wires from the in the switch cab back to the relay, which puts power to the lights.
    80392[OP] likes this.
  3. Jul 15, 2022 at 4:24 PM
    Barry
    Very cool! I actually anticipated this, and am looking at this product for inside the cab...
    MICTUNING Backlit LED LIGHT BAR Symbol Push Button with Wiring Kit ON-OFF Switch Compatible with Toyota https://www.amazon.com/dp/B01G1W80JI
    So, after I connect to battery, I run wires through a hole I make in a rubber seal near the steering wheel?
    And I could disconnect the provided switch for a switch that fits into Tundra dashboard button area?
    And if I plug it all in correctly... 3 lights come on when I push the OEM style switch?
    And my battery doesn't go dead overnight. Correct? Bueller? Bueller? :) https://youtu.be/KS6f1MKpLGM
  4. Jul 15, 2022 at 5:08 PM
    ConcordCarlos
    Carlos
    2021 Tundra SR5
    Yes on all…except if you wire straight to the battery and leave it on, yes dead battery. You may want to wire the trigger on the relay to an ignition controlled circuit. I’ve got all my accessories running through a SwithPros set up , so it’s been a while since I did one circuit ignition controlled.
    The firewall grommet is near your ABS, look down down from there for the rubber boot.
    Is the stock switch 3 wires or two?
  5. Jul 16, 2022 at 4:11 AM
    Barry
    Understood, thanks.
    I am not sure about the stock switch, as I don't have the item in hand. BUT I found this wiring diagram in the Amazon description... https://m.media-amazon.com/images/I/61z3CV+OsmL._AC_SL1500_.jpg
    An ignition controlled circuit... So when the car is turned off, the light bars also go off. And when the car is turned on, the light bars can only then be turned on?
    Does that mean I could wire into the fuse box thing in the Tundra dash?
  6. Jul 16, 2022 at 6:21 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I would advise you to do some more research.
    Using magnetic mounts will no only look bad, but damage your vehicle, cause your lights to be stolen rather quickly.
    Proper ditch light brackets would prevent damage and your lights will stay with your truck longer before someone walks off with them.
    Second. The pre-wired harnesses often cause more headache than they are worth.
    You will want to use a weatherproof relay with fused power coming directly off the battery. Then, you will use an add-a-fuse to tap into the circuit of your choice (either an ignition or light circuit) for the switch. The switch controls the relay, the relay controls the lights.
    As for the switch you posted, I have had good luck with both Mictuning and CH4x4. Same switches, different packaging. But, with CH4x4 you seem to get more options on the faceplate design.
  7. Jul 16, 2022 at 6:38 AM
    Barry
    Understood, thanks!
    Before magnetic mounts, I was looking at the following...
    Rough Country For Toyota 2"LED Ditch Kit 14-20 Tundra https://www.roughcountry.com/toyota...=2021-toyota-tundra-2wd-760664&sid=72kIc1vGDd
    texasrho83 likes this.
  8. Jul 16, 2022 at 7:20 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    ^^^This!
  9. Jul 16, 2022 at 7:29 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ch4x4 and Air On Board are your go to places for OEM style switches
  10. Jul 16, 2022 at 7:34 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm a fan of RC for some things but their light pods/cubes isn't one of them. I have them on my bumper (came with) and one of them has condensation so yeah...go with Diode Dynamics if you're trying to ball on a budget but want quality.
    For a hood mount, try
  11. Jul 16, 2022 at 7:57 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You should definitely get security hardware for exterior lighting. The best would be screwdsecurity.com but anything is better than nothing.
    Keep in mind you can also run wire through the firewall on the passenger side. Its a little more open.
    Switch pros would make future electrical 10000% easier.
    ConcordCarlos and 80392[OP] like this.
  12. Jul 16, 2022 at 8:09 AM
    Windsor
    Homeless in Oregon
    Some.
    Also, if you intend to add multiple accessories, I'd suggest looking at a Bussmann RTMR aux fuse panel. It will give a cleaner look and provided fused and relayed circuits.
    80392[OP] and MadMaxCanon like this.
  13. Jul 16, 2022 at 8:20 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This guy is gonna delete his account lol probably thinking "damn I gotta be rich to come here"
  14. Jul 16, 2022 at 8:27 AM
    MadMaxCanon
    I mean......yeah, kinda.
  15. Jul 16, 2022 at 9:09 AM
    Windsor
    Homeless in Oregon
    Some.
    It's a hazard of this place.
  16. Jul 16, 2022 at 9:44 AM
    AppleFarmer
    AppleFarmer New Member
    21 Tundra Platinum
    I’m a huge fan of ditch lights and want some badly but my issue is that the car wash. Because of my work I’m off road 6-days per week, under sprinkler systems and on mostly dirt roads. The combination has me needing to wash my truck frequently.
    Ain’t nobody got time for a driveway wash with a foam cannon 3x per week.
    I hit the car wash. Everything has to be super secure or it’ll get ripped off limiting options.
    think about it…
  17. Jul 17, 2022 at 5:40 AM
    Barry
    Great point... I assume magnetic mounts would be especially prone to damage in a touch car wash...
    I already have that issue with my Softopper, as they are recommended only for "touchless" car washes.
    As for the money for this stuff... let's just say I like to know my options. That said, I don't hesitate to spend more for demonstrated quality... as someone on this forum once said: "Buy once, cry once" :)
  18. Jul 17, 2022 at 5:43 AM
    Barry
    Just to hear even MORE viewpoints... :)
    • White vs Amber lights?
    • Daytime Running Light feature or no?
  19. Jul 17, 2022 at 9:05 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    As long as your ditch lights are secured to the brackets, running through the car wash is no problem. I’ve ran my truck through the car wash numerous times and the ditch lights are secured.
  20. Jul 17, 2022 at 9:07 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    That’ll just be more personal preference, but if you tend to go through dusty environments, Amber will cut through dust/fog more easily than White.
    DRL doesn’t matter, that’s personal preference too.
    80392[QUOTED][OP] likes this.
  21. Jul 18, 2022 at 6:07 AM
    king.cong.1119
    king.cong.1119 New Member
    amber for inclement weather condition, fog, dust, snow, etc
    I'd strongly recommend a control panel, budge friendly one can be auxbeam 6 or 8 switch (thats what I have) and then you don't need to run wires thru firewall every time you add an accessory.
  22. Jul 20, 2022 at 7:02 PM
    ConcordCarlos
    Carlos
    2021 Tundra SR5
    I’ve ran Rigids,Baja Designs and generic Amazon junk LEDs. What your $$ gets you(Rigids and BD) is high quality optics and actual IP rated seals. For everything but back up/aux reverse lights the low $ stuff is going to disappoint IMO.
