Wiring Diode Dynamics Stealth bar to MicTuning Light Bar Button
Discussion in '2.5 Gen Tundras (2014-2021)' started by ExcludedTim, May 11, 2020.
  1. May 11, 2020 at 3:10 PM
    ExcludedTim
    ExcludedTim [OP] New Member
    2015 BRM SR5 DC
    Hey Guys,
    Was planning on doing some Front End work this coming weekend but I'm not the greatest at understanding wiring (Superfan of all things Plug and Play). But I just can't stand the way the Diode Dynamics Stealth Bar switch looks (completely not factory).
    I went ahead and ordered a MicTuning Light Bar button in hopes that i could do away with this ugly thing and at least have something "Stock" looking in it's place.
    https://www.amazon.com/gp/product/B0117B1J3W
    Problem is, this Switch came with 4 wires compare to the 3 on the Diode Dynamics one. What do I need to do to make this work in place of the toggle button? I want the replacement switch to light up when the Dash gets turned on, and when I'm toggling the button on only.
    I've tried to Google this request and I saw some promising details but nothing that flat out says Tundra specifically. I'm turning to the Guru's here to help tell me where to solder/t-tap/crimp/etc...
    Thanks in advance
  2. May 11, 2020 at 4:45 PM
    pillpusher84
    pillpusher84 New Member
    2024 Silverado High Country
    According wiring diagram for the switch you purchased:
    1 (Green) = 12v power source (ie. battery)
    2 (Red) = connect to the power input for the light bar
    3 (Red) = Illumination circuit (connect to the 12v+ for other dashboard switches, so it illuminates with headlights on)
    4 (Black) = Chassis Ground
  3. Aug 18, 2021 at 11:15 PM
    cmox2
    cmox2 New Member
    2017 Tundra Crewmax Platinum
    Bilstein 5100 Wheeler’s off-road single AAL Diode Dynamics 30 inch Stealth LED Light Bar Diode Dynamics SS3 LED Fog Light
    Hey Tim did you ever get your light bar hooked up? I have a similar setup but I’m having issues with the wiring. I have my red 1 (from the switch) connected to the blue wire on the harness. I have green going to white and black going to black. I don’t have the red 2 wire on the switch (red wire next to the black wire on the switch) connected right now. The switch lights up when pressed but the light bar won’t turn on. Any ideas?
  4. Aug 18, 2021 at 11:26 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Take a look at this video: https://youtu.be/W4MXEJpedrM
  5. Aug 19, 2021 at 2:47 PM
    cmox2
    cmox2 New Member
    Thanks for the link. I followed the videos to the “T” but still no luck. I tested the light bar and it does work. I also replaced the relay and the fuse. They only thing I can think of is maybe the harness is bad? The switch will power on so the harness should be good right?
  6. Aug 19, 2021 at 3:58 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    There might be a chance the harness can be bad… where did you get the harness?
  7. Aug 19, 2021 at 4:23 PM
    cmox2
    cmox2 New Member
    I’m using the wiring harness that came with the light bar from Diode Dynamics. I may order another harness from them to see if that fixes it. If not I may have to take it to a shop and have someone else troubleshoot it.
  8. Aug 19, 2021 at 4:59 PM
    cmox2
    cmox2 New Member
    I’m using the below stock wiring harness from Diode Dynamics. Do you think I should try to make my own harness? 9DEE6441-8CCD-4942-A78E-BF4E9265C06A.jpg
  9. Aug 19, 2021 at 5:16 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Honestly, go to your local HF and pick up their wiring harness. Same exact one as the CaliRaisedLED and I’m sure it’ll be the same as your DD harness.
    They’re all the same 14ga stranded wires.
  10. Aug 20, 2021 at 6:29 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    First if you have the quick connect on the harness from switch to relay pull it apart. Turn the switch on and check for power at the connector on the switch side. If power there move to to the relay. Check for power in to the relay. Next check for power out of the relay. Make sure you use the corresponding grounds when testing.
  11. Aug 23, 2021 at 7:46 PM
    cmox2
    cmox2 New Member
    I just wanted to give you guys a quick update. I went to HF and bought a new wiring harness. After installing the new harness everything worked! Thank you all for your advice. I really do appreciate it.
    7A7AC325-C326-477F-9C9E-C7746BFB597E.jpg A01012DB-ADA8-4D90-950C-89BA5F446C4F.jpg
  12. Aug 23, 2021 at 7:48 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Nice! Glad picking up that harness fixed everything for you!
    Lookin’ good!
  13. Aug 24, 2021 at 10:42 PM
    20Tundra_sauce21
    20Tundra_sauce21 New Member
    I see you got the 30” stealth and the DD fog in amber. How do you like that color combo white and amber?
  14. Aug 25, 2021 at 7:39 AM
    cmox2
    cmox2 New Member
    I love the color combo. I went with the DD Sports and they are brighter than I thought they would be. The nice thing about them is that they are street legal. The 30 inch light bar is great for lighting up dirt/back roads. I’m happy with the setup so far.
  15. Aug 25, 2021 at 8:04 AM
    20Tundra_sauce21
    thinking about the pro amber! I’ll be deciding today
  16. Aug 26, 2021 at 7:16 PM
    cmox2
    cmox2 New Member
    If you haven’t ordered yet I would wait for Labor Day weekend. DD is always running sales on holidays.
    20Tundra_sauce21 likes this.
  17. Aug 26, 2021 at 7:56 PM
    20Tundra_sauce21
    I ordered already from hotshot off-road. Any idea what the discount may be?
  18. Aug 27, 2021 at 8:32 AM
    cmox2
    cmox2 New Member
    No I’m not sure. I haven’t seen anything yet. Enjoy the lights. I think your going to be happy with them. Post pics once you get them installed.
  19. Nov 2, 2023 at 6:38 AM
    evanhauer
    evanhauer Snow Chaser
    Erik
    VT
    ‘16 Tundra CM SR5 TRD OR 4x4
    Going through this process now myself. Posting this video below in addition to what's been posted above in case anyone finds it helpful. It's got a little more detail on the accessory/"valet" lighting of these buttons (illuminated when headlights are turned on vs only illuminated when button is activated).
    https://www.youtube.com/watch?v=SbXkLwCS53o&t=701s
