Wiring diagram?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Brostache, Feb 25, 2020.
  1. Feb 25, 2020 at 6:17 PM
    Brostache
    Brostache [OP] New Member
    I have a 2017 tundra and would like to addd an amplifier and sub. However i cannot find the speaker or stereo wiring diagram anywhere. I need to know speaker color codes and 12v+ and ground.
  2. Feb 25, 2020 at 6:46 PM
    tgo
    tgo New Member
    Central VA
    2018 Limited CM Silver Sky
    crutchfield.com
  3. Feb 25, 2020 at 8:37 PM
    spdrcer26
    spdrcer26 New Member
    Bakersfield, CA
    2017 Crewmax
    Do you have jbl or non jbl
  4. Feb 26, 2020 at 4:36 AM
    Brostache
    Non jbl
  5. Feb 26, 2020 at 7:14 AM
    spdrcer26
    Bakersfield, CA
    2017 Crewmax
    Best option is to use a lc7i - remove the amp under the passenger seat and wire everything from there using a harness from here https://autoharnesshouse.com/41112.html
    I did a 5 channel amp w/ a 10” and everything wired up easy with the harness connected under the passenger seat
  6. Feb 26, 2020 at 7:15 AM
    spdrcer26
    Bakersfield, CA
    2017 Crewmax
    Here is what it looks like
    purplenova likes this.
  7. Feb 26, 2020 at 7:17 AM
    spdrcer26
    Bakersfield, CA
    2017 Crewmax
    This is the wire diagram from a fellow tundra member that worked perfect with the harness on my 2017
  8. Feb 26, 2020 at 7:27 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    You are going to need a LOC or like mentioned above you can use a DSP...if you are keeping your stock HU....that way it converts the stock speaker harness to RCAs to plug into your amp
    But I'm not an audio professional and could be totally wrong here....but even if you get an aftermarket HU you will want to get the 4438 Harness so that you can connect to the factory speaker wire harness at the stock amp location (under the passenger seat) if you don't want to run all new speaker wires from the amp to the doors etc...
  9. Feb 26, 2020 at 7:30 AM
    LogCabins
    'Merica
    2017 TRD Pro
    if you would like to really simplify things...reach out to James at Tech12Volts, hands down best customer service and he knows Tundra audio like no other.
  10. Feb 26, 2020 at 8:08 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    We have the same setup...
    Guzcarr likes this.
