Wiring air horns to factory setup
Discussion in '1st Gen Tundras (2000-2006)' started by cbearr68, Sep 1, 2019.
  1. Sep 1, 2019 at 12:32 PM
    cbearr68
    cbearr68 [OP] New Member
    Sunset Beach Nc
    07 Tundra ddl door 2wd
    Led lighting new wheels
    Ok tundra Gods this my first tundra I have ever owned and I’ve done a lot of work on here but the last major thing I’m trying to figure out is how to wire my air horns to the factory setup using everything that came with the Air horns without going into the steering wheel....
  2. Sep 1, 2019 at 12:57 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Use a relay with the factory horn wire as the control side. All wiring will be done in the engine bay.
  3. Sep 1, 2019 at 1:50 PM
    cbearr68
    Sunset Beach Nc
    Which one is the actual horn wire to use the passenger side had one wire and the driver side horn has two wires
  4. Sep 1, 2019 at 2:03 PM
    Welcome from NY.
  5. Sep 1, 2019 at 2:37 PM
    cbearr68
    Sunset Beach Nc
    Thank you I have had a lot of questions about the tundra and kinda figured it out on my own...This one is really kicking my butt lol
  6. Sep 1, 2019 at 3:05 PM
    Windsor
    Homeless in Oregon
    Some.
    Both horns should be grounded through their mounts. The plug in the driver side horn has 2 wires attached. One is inlet from the horn circuit, the other is outlet to feed the second horn.
    Edit: both wires in the plug should be attached on the same connector.
  7. Sep 1, 2019 at 3:52 PM
    Windsor
    Homeless in Oregon
    Some.
    Are you wanting to run only air, or have the option to switch between air and OE horns?
  8. Sep 1, 2019 at 5:05 PM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    Welcome, which horns are you going to install?
  9. Sep 1, 2019 at 5:26 PM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    As the previous poster mentioned, you can simply use the wire going to the stock horn as the "control" wire (low amp) for a relay. When the relay feels the voltage from that wire, it should open its switch for the high amp side to run the compressor.
    Black Wolf likes this.
