Wiring a light bar question
Discussion in 'Lighting' started by soarvet, May 14, 2018.
  1. May 14, 2018 at 4:52 AM
    soarvet
    soarvet [OP] New Member
    2017 Silver Tundra Crewmax 4x4 XSP package
    Quick question, when you guys wire up a light bar are you going directly to the battery for power or splicing into somewhere else. I need to wore up my light bar. The directions are pretty vague.
    Another question. My switch has 4 wires, black (ground), green, and 2 red with orange stripe. I get one is power and one is ground, what would the other two wires be for?
  2. May 14, 2018 at 5:22 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Also curious
  3. May 14, 2018 at 5:26 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    I tied directly to the battery and kept the relay under the hood as well and only had to run the switch wire through the firewall.
    Is yours a lighted switch?
    MotoTundra and soarvet[OP] like this.
  4. May 14, 2018 at 7:02 AM
    soarvet
    Yes, it is backlit. Thank you for the document. That clears things up for me.
    NewImprovedRon likes this.
  5. May 14, 2018 at 7:03 AM
    soarvet
    It is backlit.
  6. May 14, 2018 at 7:13 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Depending on the size/ wattage of your light bar, you should probably be using a relay.
  7. May 14, 2018 at 7:14 AM
    RickC
    Rick
    Knoxville TN
    Ok, that explains the 4 wires. Ron posted a file that shows a possible wiring diagram. The colors might not match, but I would have thought your kit came with wiring instructions at least detailing the color code of the wires for the switch.
    soarvet[OP] likes this.
  8. May 14, 2018 at 7:48 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Mine came with a harness directly wired to the battery, with a push button switch which I cut off and passed through the firewall (wires only) and added an LED switch, fuse tapped inside to illuminate the switch.
    https://youtu.be/K_AVZqezCBE
    Not my pic but same end result, lower middle switch:
    pyrite12, colenation and soarvet[OP] like this.
  9. May 14, 2018 at 7:54 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    JoshuaA likes this.
  10. May 14, 2018 at 8:42 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    X2
  11. May 14, 2018 at 9:05 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Another option as well,
    https://caliraisedled.com/collections/toyota-tundra/products/8-switch-panel-power-system
    @Caliraisedled
  12. May 14, 2018 at 12:53 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
  13. May 14, 2018 at 1:04 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Direct to the battery. Used the Baja Designs wire harness. It's a little pricey, but I was on a time limit and new the harness could do what I needed. Utilizes a relay so I could use a Mictuning factory OEM looking switch.
  14. May 14, 2018 at 2:46 PM
    soarvet
    I found the same diagram. Thanks
