DIY: Wireless Phone Charging
Discussion in 'General Tundra Discussion' started by thekorymiller, Jan 18, 2017.
  1. Jan 18, 2017 at 9:54 AM
    thekorymiller
    thekorymiller [OP] New Member
    Kory
    2019 Tundra SR5 Cement 5.7 V8
    I finally did it! I installed wireless charging where it should go and it is amazing, I love it!
    Check it out:
    First thing, remove this black piece, be sure to keep up with all the screws there are quite a bit of them, and something nice to have would be a magnetic screw head, these screws underneath are small
    Next Mark out your cuts and use a Dremel or similar tool to get rid of the plastic, I used a Dremel with a metal cutting bit and it cut this plastic like butter, be very careful and take your time you could cut through at any point.
    Make sure you have a nice snug fit, this will be nice when going to tape.
    Snug fit! Test and make sure you can charge at this point, I have to go back and shave very little pieces to ensure it would fit as snug as possible without poking through.
    Tape it down, press down and tape it down, you want the charger to be in there very tight and I used electric tape and I did not skimp on the tape, since I really do not want to go back in there.
    Re-install piece
    Re-install cover
    Final product and fully working wireless charging pad! Should have done this sooner!
    Enjoy!
  2. Jan 18, 2017 at 9:57 AM
    Added to the DIY section (sticky)
    Sixpack and Bob like this.
  3. Jan 18, 2017 at 10:10 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Sweet mod man.
    thekorymiller[OP] likes this.
  4. Jan 18, 2017 at 10:11 AM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Qi charger right?
    Nice job!
  5. Jan 18, 2017 at 10:13 AM
    thekorymiller
    Kory
    This was just a extra Samsung charger i had around
    AnonVet likes this.
  6. Jan 18, 2017 at 10:15 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    nice job!
  7. Jan 18, 2017 at 10:19 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Man. Now I dislike my IPhone even more. Miss my Sammy.
  8. Jan 18, 2017 at 10:20 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good work. Clean install.
  9. Jan 18, 2017 at 10:21 AM
    csuviper
    Broomfield, CO
    Yea Samsung really jumped above the rest by competing this first and getting the patent. Once the patent runs out the rest will have it.
    TRD-tv and 14limited like this.
  10. Jan 18, 2017 at 10:29 AM
    Bob
    Bob
    The only thing I don't like about my new phone (first in 2 years) is the lack of wireless charging. That was my favorite feature about my older, and cheaper, phone.
    T-Rex266 likes this.
  11. Jan 18, 2017 at 11:29 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    this is something I have been thinking of doing great job @thekorymiller :thumbsup: nice write up I will be doing this in the near future
  12. Jan 18, 2017 at 11:37 AM
    ToyotaTundraMike
    2015 Tundra
    Sweet! Add this to the list of reasons not to get the bench seat up front.
  13. Jan 18, 2017 at 12:07 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Very nice. I've been wanting to do something like this. Was looking for a charger I could double side tape in that tray. But this is way better.
  14. Jan 18, 2017 at 12:48 PM
    It is pretty bad ass to have wireless charging. Really enjoy mine.
    NewImprovedRon likes this.
  15. Jan 18, 2017 at 12:50 PM
    Mophie cover works great with the iPhone. FYI
    Lilly likes this.
  16. Jan 18, 2017 at 12:52 PM
    duerj70
    duerj70 New Member
    2017 Tundra 1794 Super White
    Nice job.
  17. Jan 18, 2017 at 1:00 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Samsung has a patent on inductive charging? Im honestly curious and Im not trying to argue, I just don't see how thats possible seeing as it's the same (very old) technology that transformers and relays use.
  18. Jan 18, 2017 at 1:01 PM
    csuviper
    Broomfield, CO
    I believe in a phone application yes. That is what I heard anyway and reason why the others don't have it.
  19. Jan 18, 2017 at 2:30 PM
    Pudge
    CT
    @thekorymiller do you have a case on your phone? I have an S7 and the charger works fine through the case but curious to know if it would go through the case and the black plastic tray.
    Also do you have any issues with positioning of the phone? I know sometimes it can be finicky
  20. Jan 18, 2017 at 2:37 PM
    thekorymiller
    Kory
    @Pudge, I have a very thin case and it can be somewhat temperamental with the case on, but it non the less works 90% of the time with the case on.
    As for the position of the charger, great question, I basically played with the charger and the phone positioning with nothing else and just had to guess. I gauged where the charger and the phone connected at its strongest or where the "sweet" spot was and luckily I was pretty spot on. Also, once the phone establishes the connection with the charger it does have more of a connection and thus not really having an effect if the phone moves in the tray while driving. This has been my experience and this is also day one!
    Pudge likes this.
  21. Jan 18, 2017 at 2:38 PM
    Pudge
    CT
    Thanks man I'll be doing this soon
  22. Jan 18, 2017 at 3:00 PM
    Mike Tread lightly.
    south carolina
    I miss wireless charging on my Nexus 6p..
  23. Jan 18, 2017 at 10:33 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Really cool mod! I learn something here every day.
  24. Jan 19, 2017 at 6:44 AM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
  25. Jan 19, 2017 at 7:51 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Wireless induction charging is not new by any means, but in an android application it sure is. It's just the old saying "there are 10 ways to skin a cat", Samsung just patented the "one way" to do it. I'm sure apple will think of some ingenious way to do it themselves.
  26. Jan 19, 2017 at 8:25 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    They do make wireless charging cases for the iPhone. There are 2 types of wireless charging, normal (slower) wireless charging, and fast wireless charging, the phone and the power adapter itself also has to support the fast wireless charging or it wont work. I didn't know about the fast wireless charging until I had the Note 7, before the battery burning. It is a great feature though no more cable to plug in.
  27. Jan 19, 2017 at 5:32 PM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Samsung is just one of the big players that has fully endorsed wireless charging. They dont have any kind of patent that is stopping anyone else from using wireless charging.
    LG, Motorola HTC, ASUS, Sony, and BB (yes, blackberry. Remember them?) have phones with wireless charging capabilities. Not even getting into the Chinese brands.
    You might be surprised but Nokia has the same number of phones (actually more if you subtract the Note7) as Samsung that support wireless charging out of the box.
    Samsung didn't even offer it until the S6 Galaxy line. (2015)
    Hope this clears things up.
    I'd expect Apple to probably support wireless charging with the next phone but they play by their own rules dont really follow market trends.
  28. Jan 22, 2017 at 4:52 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
  29. Jan 22, 2017 at 5:23 PM
    csuviper
    Broomfield, CO
  30. Jan 23, 2017 at 6:29 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Have you had any issues with heating up while charging? I'm trying to cover all of my bases before I take a crack at it. TIA
