Wire Gauge Inquiry
Discussion in 'Lighting' started by texasrho83, Jun 28, 2018.
  1. Jun 28, 2018 at 8:36 AM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    So long story short, dealership replaced my "body ECU" but stated my aftermarket wiring overheated and started smoking.
    I'm of the mind my old ECU wasn't putting out whatever power it should've been and this new ECU is pushing full power but my wiring wasn't the right gauge and couldn't handle it.
    That being said, what gauge wire should I use for aftermarket things like light bars, rock lights, fogs? I am pretty sure 16 ga isn't sufficient and overheated...
    TIA
  2. Jun 28, 2018 at 8:39 AM
    n2deep
    n2deep Pavement Princess
    Depends on the draw of the light bars. You didn't mention what size bar and how many amps it pulls. Gotta do the math
    14burrito likes this.
  3. Jun 28, 2018 at 8:41 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    What does your ecu have to do with light bars, or is it two separate issues?
    14burrito, texasrho83[OP] and n2deep like this.
  4. Jun 28, 2018 at 8:42 AM
    n2deep
    Your light bars should be wired to the battery direct with a relay - good point. Shouldn't have anything to do with the ECU.
    iHacker and texasrho83[OP] like this.
  5. Jun 28, 2018 at 8:45 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It is...
  6. Jun 28, 2018 at 8:48 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Anything directly connected to the battery bypasses ECU involvement? So now I’m questioning why my aftermarket wiring overheated.
  7. Jun 28, 2018 at 8:51 AM
    n2deep
    You have to give us more info. 16ga wire will run some some things just fine. Bu what do you have hooked up? What size fuse you running? Fuse should blow before wire melts. Wire gauge, length, amp draw and fuse size all play a part
    texasrho83[OP] likes this.
  8. Jun 28, 2018 at 9:04 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have fog halos, CB, 8 pc rock lights, and 42” light bar directly connected to the battery.
    Everything has an in-line fuse. The bar and rock lights are remote activated. CB has full-time power and must be manually turned off as do the halos.
  9. Jun 28, 2018 at 9:06 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I will bet anything I need to up the gauge wire I’m using. I’m just confused as to how a new ECU would cause this if everything is direct-connected to the battery?
  10. Jun 28, 2018 at 9:09 AM
    n2deep
    The rock lights should be fine on 16ga depending on the draw. But everything else I would think would need bigger wire. What is the draw on the 42in bar? You need to know the draw so you can make sure you have the correct size wire. How many amps does the 42 bar draw?
  11. Jun 28, 2018 at 9:16 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Probably needs a 20A fuse which I’m pretty sure it has. The included harness had a relay, switch, and fuse.
  12. Jun 28, 2018 at 9:25 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    I’m running 10 gauge with a 20 amp fuse. I know it’s overkill but better safe than sorry.
  13. Jun 28, 2018 at 9:52 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Technician told me I should run 12 ga w/small fuse so the fuse pops quickly if a problem comes up.
  14. Jun 28, 2018 at 10:32 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  15. Jun 28, 2018 at 10:37 AM
    n2deep
    Yeah I am not a fan of the included wire harness that companies send - just seem under sized. Upgrade to 10ga or 12ga depending on length and amp draw.
  16. Jun 28, 2018 at 4:14 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    UPDATE: So the body ECU/fuse block fried again. The dealership tried to tell me it would be my financial responsibility to cover the repairs and I was polite when I responded "It was working when I left here, I didn't touch anything, checked the lights when I pulled into my driveway and now they aren't working. Seems to me this points to something y'all didn't check well enough." I asked to speak to the service manager. My service writer comes back with #2 in charge and says they'll cover the repair as a "one time goodwill gesture" provided that I pull off every aftermarket lighting source I have added. Seeing the compromise, I agreed to it. I was going to pull all the wiring anyway. I'm taking out the CB, light bar, fogs, and Spyders. Ugh.
    The cost of the repair is $1100-1200.
  17. Jun 28, 2018 at 5:38 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    You also need to take into account the length of the wire run as well. Plenty of charts for a good reference point on google.
