Wire/cable for Engine bay
Discussion in 'General Tundra Discussion' started by kurtwp, Feb 25, 2018.
  1. Feb 25, 2018 at 3:05 PM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    Would like some suggestion on the best type of wire ( 2 - 2/0 gauge ) to use in the engine bay.
    Kurt
  2. Feb 25, 2018 at 3:26 PM
    I go by how much current is going to be running through any particular wire and kick it up a notch to the next higher rated gauge if needed.
  3. Feb 25, 2018 at 4:11 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    What are you using it for? #2 and 2/0 is huge. My guess is anything you are going to run will need nothing more than #12 and possibly/probably smaller.
  4. Feb 25, 2018 at 4:13 PM
    Yeah, my freakin main winch cables are 0. ^^^^^
  5. Feb 26, 2018 at 5:10 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    I am asking the type of cable. Would welding cable be better or wiring that can handle heat and grease? Just asking for suggestions on what people had the best experience with. There is a lot of information on the web but still, want real user input.
    Kurt
  6. Feb 26, 2018 at 5:20 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Kurt, what is the application for? Sounds like you are more interested in the wire jacket than the size of conductor.
  7. Feb 26, 2018 at 6:19 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    Yes, my concern is about the jacketing but the size will be at least 2 gauge wiring which will run from the engine bay to the bed of the truck. I know welding cable is very flexible (at the larger gauge wiring) and can handle high volts/amps but can it take the heat and grease of the engine bay and road. I know I can run the cable through wire looms to add additional protection. Just looking for Tundra owners input on their experience with running large wires from the battery to other parts of their truck.
    Kurt
  8. Feb 26, 2018 at 7:16 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    At my shop we use welding wire. 100% copper strand with a oil / uv resistant silicone jacket. Gauge size is dependent on voltage needed and length of run. Welding wire seems to be the easiest to bend and maneuver. Regardless of the jacket, I always loom the wire and wrap with cloth electrical tape for abrasion and weather resistance. And if I absolutely can't avoid a high heat area I use heat reflective tape. Hope that helps.
    15whtrd likes this.
  9. Feb 26, 2018 at 7:52 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    Yes, that does help. @duece292 who do you use for your supplier.
    Kurt
  10. Feb 26, 2018 at 11:24 AM
    duece292
    Greg
    Green Bay, WI
    We use Del City. They're a WD / jobber supplier for pretty much anything aotomtive electrical.
