Wiper Blade Resting/Off Location ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Patriot 1776, Feb 18, 2021.
  1. Feb 18, 2021 at 6:54 PM
    The Patriot 1776
    The Patriot 1776 [OP] Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    I left my wipers on when I turned my truck off. The next time I started it, ice was on my windshield and it jacked up the wiper location. They went up all the way but were stopped by the ice coming down and got in a bind. Now the furthest they go down during the cycle or turned off is about 3” higher than normal. They’re not bent. It seems like they rotated on the studs they’re mounted on but I don’t think that can happen w/out them stripping the knurling on the studs and that didn’t happen. How do I go about getting them to go down all the way like before?
  2. Feb 18, 2021 at 7:20 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    So you took them off and nothing seems stripped? Have never had mine off, is there a key that aligns them together, or can they be placed anywhere on the splined stud?
    The Patriot 1776[OP] likes this.
  3. Feb 18, 2021 at 7:22 PM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    See if you can find alignment marks on the windshield. They are small marks used to align the wipers during installation. Just loosen them up and set them on the marks and tighten them back down.
  4. Feb 18, 2021 at 10:11 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I did not but they’re functioning normal. From past experiences with similar instances, the wipers wouldn’t function properly due to the studs getting stripped. This is like they reset themselves to a different arc of motion length, which seems pretty much impossible.
    I will look for this.
    HulkSmurf14 likes this.
  5. Feb 19, 2021 at 2:01 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I used a bit of force and they went back into place. I guess they’re just pressed onto the stud and it has no knurling. I didn’t want to force them but saw no other option. Hopefully the studs don’t get jacked up from this. Thanks for the input!
    TILLY likes this.
