Winter Washing
Discussion in 'Detailing' started by k9shag, Dec 15, 2017.
  1. Dec 15, 2017 at 4:58 PM
    k9shag
    k9shag [OP] New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I have searched the forum. But I am looking for the best stuff (waterless) to use in colder weather. I am used to washing my Tundra once a week with the two bucket method. I use almost all Adams products, but do not have there waterless. I have researched it and I am very familiar with Dri wash and guard, but would like to know what works best in colder weather. I sent War Eagle Steve a message but he might be busy so I thought I would reach out to the hive.
    driverdog and AxelsHumanDad like this.
  2. Dec 15, 2017 at 5:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    What kinda "cold weather" are you talking about...
    I just used Carpro EcH2o and Reload together (its called Merlins Magic Elixir....look it up) for the first time and it took my dirty truck to shining like a new penny.
    driverdog and NewImprovedRon like this.
  3. Dec 15, 2017 at 5:11 PM
    k9shag
    Tony
    Midland, NC
    winter washing after a few freezes I am reluctant to use my hose even when the ambient temp is in the 40's
    AxelsHumanDad likes this.
  4. Dec 15, 2017 at 5:31 PM
    BIGUGLY
    Paul
    2018 Limited
    You should be fine in the 40 degree range. I have to keep my work ride presentable all year and it will get washed and then out into sub zero weather. Just have to make sure you dry around the seal inside the door jam
    driverdog, Wynnded and Mr Swervlin like this.
  5. Dec 15, 2017 at 5:52 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Just washed mine last night when it was 28. It was covered in road salt. Had to be done. Also dry out you door handles. Found out the hard way when trying to enter the truck the next morning
  6. Dec 16, 2017 at 7:19 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I will typically wait until it gets above freezing, but I will only hit the car wash with the pressure washer.
    Then once it is over 40 and we get a warm stretch I will try to do a quick hand wash, but it's usually a waste of time until Spring.
  7. Feb 3, 2018 at 3:00 PM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    Sub'd
  8. Feb 3, 2018 at 4:17 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    I go to the wand wash in the winter, cost more than doing it at home but it's a lot warmer!
    driverdog likes this.
  9. Feb 4, 2018 at 4:24 AM
    JohnH
    JohnH From PA
    Pennsylvania
    No questions here...I'm just seeing what everyone else does for Winter washing.
    Thanks
    driverdog and SouthBoundSteve like this.
  10. Feb 4, 2018 at 5:04 AM
    PermaFrostTRD
    Northern NY
    Winter is drive through only. Never use the brushes (automatic wash) or ones on a stick in the “do it yourself” bays. I use the ones typically called “laser wash” or something similar.
    Consists of: High pressure water, undercarriage wash, soap x 2, rinse, “sealant”, final rinse, high powered blower dry. $11 once a week (usually- sometimes they close too because of temps). $.20 discount on gas too. Can sometimes be forced to wait 30 minutes though.
    I wax the balls off the truck in the warmer months (meguiars spray - maroon bottle). And everything keeps a nice bead all year.
  11. Feb 4, 2018 at 5:14 AM
    PermaFrostTRD
    Northern NY
    Also, if you live in a “challenging” winter environment as some of us do, follow everything @SouthBoundSteve says on how to properly detail a vehicle during the spring summer fall and your truck will survive. @driverdog too. That’s what I do / have done.
  12. Feb 4, 2018 at 5:48 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    ^^ditto
    MotoTundra[QUOTED] likes this.
  13. Feb 4, 2018 at 6:09 AM
    Adam New Member
    I dont care what the temperature is. My truck will get washed once a week. Sometimes I do it at home in the garage which I know a lot of people don't have the ability to do. If it is above 20 with no wind, I will do it in the driveway. The sun heats up the cement enough for it not to freeze. Then you just take the hose off and drain. Otherwise when it is sub zero, I take it to the touchless wash somewhere. There is one about 5 miles from me that does a $6 any wash on Wed and Sun. I will be doing a hand wash today even tho it is gonna snow 5" tomorrow. I hate a dirty truck.
    T-Rex266, driverdog and classic17 like this.
  14. Feb 4, 2018 at 6:25 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    My black truck is white with salt right now and we are getting 2-5" of snow today. :facepalm:
  15. Feb 4, 2018 at 6:43 AM
    classic17
    classic17 New Member
    2017 SR5 4X4
    Winter - My main concern is getting the salt off of the undercarriage as quick as possible. I wait until the roads are fairly dry, then I run it through a touchless with an undercarriage pressure wash to try and get the salt off of the underneath. Sometimes I'll circle around and do it twice if the salt was really bad. Then I drive it home wet (I only live about a mile from the carwash), park it in the garage and dry it while spraying Adam's detail spray on it. Shines like a new one.
    If it's warm enough, I'll run it through to knock the salt off, then hand wash at home.
  16. Feb 4, 2018 at 7:54 AM
    boloson
    boloson New Member
    Optimum no rinse
  17. Feb 4, 2018 at 9:22 AM
    You’re like me. I don’t wash it every week (it’s as wekeend warrior) but certainly every couple of weeks. When it’s freezing outside, I take it to the bay wash. I use my own soap, and MF sponge. I only use their pressure washer. I then park it around the corner and dry it with WF towels.
    Inside is usually done every other week or so depending on how much it was driven.
