Winter towing - 4WD?
Discussion in 'Towing & Hauling' started by TripperIsMyCo-Pilot, Jan 21, 2021.
  1. Jan 21, 2021 at 12:14 PM
    TripperIsMyCo-Pilot
    TripperIsMyCo-Pilot [OP] New Member
    Wyoming
    ‘18 TRD 4x4 CM
    S&B CAI, 20” Fuel Dakars, KO2s, Decked system, 2 dogs
    I’ve done a little research but wanted to check here for better results. Towing 600+ miles from OR to WY in winter with our 29ft trailer should be an experience. Outside of obviously using 2WD in dry conditions can I still tow and possibly engage 4WD when the conditions deteriorate? Biggest concern is the traction with the added length behind me. I’m not a fan of the current Terra Grapplers I have on my truck in snowy conditions - but that’s a whole different post...
  2. Jan 21, 2021 at 12:27 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Yes you can tow in 4wd as needed. Only use 4wd when required and keep speed down- there are details in your owners manual about that. You dont want to be blasting 80MPH on they highway in 4wd for hours.
    Towing- slow, smooth and steady wins.
  3. Jan 21, 2021 at 12:36 PM
    GNTundra
    Gino
    2013 White
    Info says you're from Wyoming. Is this correct? If so, then you know how dangerous WY is in the winter.:eek2:
    Be safe! :thumbsup:
  4. Jan 21, 2021 at 12:36 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    You should be good. Let it rip
  5. Jan 21, 2021 at 12:48 PM
    TripperIsMyCo-Pilot
    Wyoming
    ‘18 TRD 4x4 CM
    Thanks for the reply. Personally, towing isn’t an issue and snow isn’t an issue. Just the first time I’ve towed anything THIS big in potentially serious winter conditions. Not planning on setting any speed records this time
    2mchfun likes this.
  6. Jan 21, 2021 at 12:52 PM
    2mchfun
    Keep the gas topped up just in case you run across a road closure or accident.
  7. Jan 22, 2021 at 10:54 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Don't forget chains for the trailer. You will get held up on a highway if towing a trailer without chains.
    2mchfun likes this.
