Windshield wiper pump
Discussion in '2nd Gen Tundras (2007-2013)' started by Nomad217, Sep 3, 2017.
  1. Sep 3, 2017 at 11:00 AM
    Nomad217
    Nomad217 [OP] New Member
    2007 TRD off road model steering column on/off pump switch won't work. All lines and reservoir in working order. How can I test/fix it? Wiring?
  2. Sep 3, 2017 at 12:03 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    First, check fuses. If they're good, Locate the pump and try to jump it w 12v. There should/might be a plug for it. That way you can isolate it. If pump works then you know it's either bad switch or wire. Then you get to have some fun w elec meter.
    Let us know.
    NewImprovedRon likes this.
