windshield wiper fluid not working
Discussion in '2nd Gen Tundras (2007-2013)' started by killer08, Nov 27, 2016.
  1. Nov 27, 2016 at 12:29 PM
    killer08
    killer08 [OP] New Member
    vinnie
    08 trd/sr5
    K&n air intake
    OK so bug juice works fine with hood up or down BUT not Latched. As soon as i close the hood all the way and it latches, pump works but no bug juice. Im so stumped checked for kinks or pin hole ,also changed washer pump just because. HELP!!!!!!
  2. Nov 27, 2016 at 12:30 PM
    Sounds like the line is getting pinched
  3. Nov 27, 2016 at 12:32 PM
    killer08
    vinnie
    08 trd/sr5
    K&n air intake
    Man i looked but will bring it back in garage and look again ,Thanks 266
  4. Nov 27, 2016 at 12:33 PM
    It's def pinching. Follow the line around the cowl space closer to the cab
  5. Nov 27, 2016 at 12:44 PM
    killer08
    vinnie
    08 trd/sr5
    K&n air intake
    will do, i was thinking maybe some wacky switch or something it just started out of know where. lol
  6. Nov 27, 2016 at 12:47 PM
    Use thread needle clean out spouts use lil air something clogging lines n pinched too
  7. Nov 27, 2016 at 4:39 PM
    TheBeast The Beach
    I had a rodent chewed mine...would spray on and off...check the whole line from the pump to the hood.
  8. Nov 27, 2016 at 4:52 PM
    killer08
    vinnie
    08 trd/sr5
    K&n air intake
    Working nights this week so gonna bring it back in the garage tomorrow and take another look. I disconnected it just before the cowl and sneaked hose through the hood tonight and with hood latched it worked . Gotta b under the cowl area. Hope to find in tomorrow.
  9. Dec 11, 2016 at 5:59 AM
    killer08
    vinnie
    08 trd/sr5
    K&n air intake
    Been very busy at work so just found problem with wiper nozzle it was kinked with hood closed right where it comes up the cowl area. i disconnected it and ran it above cowl and everything is happy now and working!Also did an oil change and gotta say, Bought a 64mm oil filter wrench online from Motiv x Tools model #MX2320. well built and works Great and made the job real easy.
