Windshield washer squirter failure - diagnosed
Discussion in '2nd Gen Tundras (2007-2013)' started by sam_i02, Aug 21, 2016.
  1. Aug 21, 2016 at 10:26 AM
    sam_i02
    sam_i02 [OP] New Member
    Sid
    2010 Tundra Roack Warrior
    Last week, my windshield washer stopped spraying - the wipers worked fine at all settings. Searched the forum, did not find a solution here, so dug into it.
    Checked all the line and found no blockage. Took the jug out and pulled the cover off the motor and the picture below shows what I found. Seems like there was a leak in the seal and washer fluid got into the motor electronics and corroded it to hell.
    Could not figure out how to get the motor out of the jug - has anyone done that successfully?
    My fallback plan it to take the jug+motor to Toyota next week and have them pop a new motor in it. The dealership is closed today, so I am not even sure how much the motor is going to be. I am most likely going to get raped :(
  2. Aug 21, 2016 at 10:30 AM
    Mike Tread lightly.
    south carolina
    If it's not in warranty goto eBay or Amazon or even local part store can get it next day..
    sam_i02[OP] likes this.
  3. Aug 21, 2016 at 1:45 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
  4. Aug 31, 2016 at 5:45 PM
    sam_i02
    Sid
    Fixed. Took less than 5 minutes to replace the motor. Purchased if for $25 aftermarket. Was $62 at the stealership.
    davesnothere and NewImprovedRon like this.
