Windshield washer nozzles
Discussion in '1st Gen Tundras (2000-2006)' started by smokey0810, Mar 14, 2021.
  1. Mar 14, 2021 at 9:25 PM
    smokey0810
    smokey0810 [OP] New Member
    '03 Tundra SR5 AC 4WD
    Mine have gone kaput. Cleaned them tonight in 99% alcohol to no avail. Hoses are flowing fine. Any recommendations for replacements?
  2. Mar 14, 2021 at 9:37 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  3. Mar 14, 2021 at 9:42 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    You can try soaking them in 'CLR' which stands for 'Calcium Lime Remover' available at most hardware stores.
    Worth a shot.
    Stumplifter likes this.
  4. Mar 14, 2021 at 9:45 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I can't find the link, but others here have used OEM misters from an FJ cruiser.
    Mists instead of stream.
    SouthPaw and FirstGenVol like this.
  5. Mar 14, 2021 at 9:48 PM
    G10dra
    G10dra Not a New Member
    use a sewing needle and reverse the water flow on the nozzle :notsure:
    joseph_womack and Tundra2 like this.
  6. Mar 14, 2021 at 9:52 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Remember when people were re-directing the nozzles so they'd spray the car behind them when they were driving???
  7. Mar 14, 2021 at 9:53 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
  8. Mar 15, 2021 at 5:35 AM
    smokey0810
    Got em. Thanks
  9. Mar 16, 2021 at 6:23 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  10. Mar 16, 2021 at 6:41 AM
    des2mtn
    Shady Grove
    Tonto cover
    Stream. They work well.
  11. Mar 16, 2021 at 6:42 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    They stream. I used nozzles similar to these to replace the broken ones on a Pathfinder I used to own.
  12. Mar 16, 2021 at 8:50 AM
    2006Tundra
    Lou
    Long Beach, CA
    I'm looking for ones that spray. I don't like the stream.
    FirstGenVol likes this.
  13. Mar 16, 2021 at 8:51 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    That’s what I did but the driver side already is clogged? I’ll see if the paper clip method will work. When they do work, it’s great, much better than a stream.
  14. Mar 16, 2021 at 1:05 PM
    Professional Hand Model
    Hand Protectors
    Here is a Mod Idea I tried with 50/50 success on my OEMs. I used a specialized small hand file to cut a horizontal groove across each hole on only one of my Sprayers. Things went well on both holes, but I went in for one more Hand Move and my file tip got stuck in one of the holes and snapped off inside. Situation fubar on that one Hole with the other Hole ‘Spraying’ pretty well with the new cut on it. A partial success!
    Next time I’ll use a Dremel with a small skinny cutter wheel to Perfect the PHM Slot Technique. Another Original Free and Effective Mod for you to enjoy. I couldn’t source the ‘Land Cruiser’ or FJ ones people have mentioned about but never has been done here.
    I’d love to see Paht Numbers and pictures if this is true.
    Note: iisaami sent me his 2 sprayers as back ups (off pahts truck) and I put one back in to replace my Fubar’d. I have an extra to experiment on with Dremel when time permits. I actually prefer the OEM stream over spray so I may not ever do it again. :rofl:
  15. Mar 16, 2021 at 8:28 PM
    SouthPaw
    2000 Limited 4x4 AC
  16. Mar 17, 2021 at 4:35 AM
    Hand Protectors
  17. Mar 17, 2021 at 5:21 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Sounds like my prom night.
  18. Mar 17, 2021 at 7:47 AM
    SouthPaw
    2000 Limited 4x4 AC
    I’ll snap some pics today but they snapped right in no problem.
  19. Mar 17, 2021 at 7:55 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Yours stream? Both my 2005 and 2006 Tundras sprayed....
  20. Mar 17, 2021 at 8:26 AM
    Hand Protectors
    Another upgrade opportunity to Heavy Duty ‘Cold Package’ if your pump goes out. I have the HD and she pumps volumes man. A subtle twist in nuance of the thread.
    JasonC. and speedtre like this.
  21. Mar 17, 2021 at 8:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I would really like to get some nozzles that shoot a spray. The stream is a joke.
  22. Mar 17, 2021 at 9:46 AM
    SouthPaw
    2000 Limited 4x4 AC
    FJ cruiser nozzles are plug and play - $30. They mist vs squirt.
    Pearl-snap and Tundra2 like this.
  23. Mar 17, 2021 at 11:32 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    My '05 has spray pattern washer nozzles.
    Pearl-snap and speedtre like this.
  24. Mar 18, 2021 at 4:51 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This may be of help to some here.
  25. Mar 18, 2021 at 7:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did you do this swap? Any particular year FJ?
  26. Mar 18, 2021 at 8:52 PM
    SouthPaw
    2000 Limited 4x4 AC
    Here you go.
  27. Mar 18, 2021 at 8:52 PM
    SouthPaw
    2000 Limited 4x4 AC
    07+ I think will work? It’s the newer bug eye FJ cruisers that will work, not the old FJ40’s.
    Tundra2 and FirstGenVol[QUOTED] like this.
  28. Mar 19, 2021 at 5:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  29. Mar 19, 2021 at 6:31 AM
    Hand Protectors
    Nice! How is the flow with these? You still get Mega flow or is it held back a bit due to spray/mist nozzle?
    Tundra2 likes this.
  30. Mar 19, 2021 at 6:37 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Will wait for pics of actual squirting. Documentation required.
    This may be chrimmas item
