Windshield washer not spraying
Discussion in '2nd Gen Tundras (2007-2013)' started by Chawk46, Jan 17, 2020.
  1. Jan 17, 2020 at 5:51 PM
    Chawk46
    Chawk46 [OP] New Member
    charles
    2013 tundra
    none
    Welcome me. I bought my 2013 brandy new. I have a wopping 16000 miles on it. I have a company van that sucks compared to my pickemup. My washers ran out of the cheap blue fluid last year. I filled it with Rain Ex a couple months ago and it won't spray. I went down to my shop tonight to do some other work and remembered the washers. I didn't mention I didn't bring my truck keys. I checked the tank and the fluid looks cloudy. I opened the fuse box and found crap and dead bees. I cleaned that out and verified contact to all of the fuses.
    Which fuse powers the washer? And does a fuse just power that? I'm kind of embarrassed cause I'm an engineer and I should pull out my manual and RTFM, that's an acronym for "read the f@ckin manual.
    Don't beat me up too much, I'm getting ready to retire after 40 years.
  2. Jan 17, 2020 at 7:12 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    It's under the instrument panel inside your truck. Fuse Nr 17 or 18
  3. Jan 17, 2020 at 8:41 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI and congrats on the pending retirement. You might want to check the lines and sprayer nozzles as well. Old washer fluid can crystallize and plug them up. A pin usually works to clean out the holes in the nozzles.
  4. Jan 18, 2020 at 4:48 PM
    Dr_Al
    Dr_Al New Member
    Al
    Can you hear the motor running when you try to spray? If not it's an electrical issue. If the motor runs then it's a mechanical issue. On my Tundra the hose rotted under the cowl and had to be replaced.
  5. Jan 19, 2020 at 9:51 AM
    FXFormat
    FXFormat New Member
    Not sure if this applies to the Tundra but most cars the washer and wipers are tied to the same fuse, if your wipers work and you're not spraying fluid, then could be a dead pump, bad wiring, or clogged nozzle.
  6. Jan 19, 2020 at 11:28 AM
    Lifeislarge
    Lifeislarge New Member
    2007 Tundra 4X4 TRD 5.7L
    If the pump is running check the little junction block on your hood where the three hoses tie in together. Mine plugged up completely and I just replaced it with a three way vacuum connector and all was well.
