windshield leak
Discussion in '1st Gen Tundras (2000-2006)' started by panran, Mar 4, 2018.
  1. Mar 4, 2018 at 2:26 PM
    panran
    panran [OP] New Member
    2002 tundra
    turbo muffler
    2003 tundra leaking inside cab at top of the windshield.Is there replacement trim?Any special tools needed?
  2. Mar 4, 2018 at 2:28 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. Post a pic. It'll help people answer the question.
  3. Mar 4, 2018 at 2:38 PM
    panran
    2002 tundra
    turbo muffler
    suppose to rain tomorrow I'll try then.Trying to get around with a broken leg.
    831Tun likes this.
  4. Mar 5, 2018 at 8:42 AM
    Casper421
    In the woods
    06 DC
    Have you replaced your windshield recently?
  5. Mar 5, 2018 at 9:06 AM
    Send a PM to @Roman he parts guy
    Roman likes this.
  6. Mar 5, 2018 at 9:18 AM
    panran
    2002 tundra
    turbo muffler
    No I have not replaced the windshield.It had a slight leak and I was putting off checking it out.Now it's much worse,and I broke my leg,so I can not get a good look on the outside.I'm thinking dryrot?Is there trim that maybe might be the cause?
  7. Mar 5, 2018 at 10:27 AM
    Casper421
    In the woods
    06 DC
    You said the leak is from the top of the windshield? Is it from a corner or in the middle? Water could be running down the rain gutters and through the weather stripping.
  8. Mar 5, 2018 at 10:51 AM
    panran
    2002 tundra
    turbo muffler
    It is worse right in the middle, above the rear view mirror at the headliner.Sorry I should have explained better.Last week it rained a lot and the headliner between the dome light switch ect. on the ceiling and the windshield was dripping pretty steady.It's suppose to start rain and snow tonight,I'll try to get pic's.Thank You
  9. Mar 5, 2018 at 1:17 PM
    Casper421
    In the woods
    06 DC
    Are you in the north east? I hope it’s just the weather stripping and not a rust hole in your roof.
  10. Mar 5, 2018 at 3:13 PM
    panran
    2002 tundra
    turbo muffler
    No...I'm in the Midwest....It's a Texas -Okie Truck.
  11. Mar 5, 2018 at 3:39 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'm guessing you need a new windshield seal, which unfortunately requires removing and reinstalling the glass.
  12. Mar 5, 2018 at 4:12 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    This
    Windshields are held in with a urethane adhesive. The trim you see on the outside is just cosmetic.
    There are really only 4 possibilities.
    In order of severity there are 4 options.
    1. New windshield install issue, installer did not have a clean urethane joint in the top center.
    Solution - Pump urethane into the hole where the leak is coming from.
    (From here on this is potentially a safety issue)
    2. Urethane not adhering to the windshield. Installer did not prep the windshield correctly.
    Solution - Remove windshield and reinstall. *may require a new windshield
    3. Rust issue, rusted out under the urethane bead. **Based on your description this would be my guess.
    Solution - Remove the windshield, sand the rust, prime bare metal, and install new windshield. ***Probably require a new windshield.
    4. Rust issue (severe) _ Pinch weld has deteriorated to the point no metal left to hold the windshield in place.
    Solution - Remove the windshield, have body shop fix the pinch weld, install windshield.
  13. Mar 6, 2018 at 4:36 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    I have the same issue leaking in the same spot and I think my only cure is to replace the windshield. Now mine is all sandblasted so would be worth it for me.
