Window Switch Recall
Discussion in '2nd Gen Tundras (2007-2013)' started by OBXTundra, Nov 14, 2018.
  1. Nov 14, 2018 at 12:43 PM
    OBXTundra
    OBXTundra [OP] Member
    Southeast USA
    2018 Nissan Armada, 4x4
  2. Nov 14, 2018 at 3:18 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I haven’t gotten any notice...just checked toyota.com/owners and it says “no safety recalls” for my specific truck.
    My passenger side window has been making noise rolling up since 2013 and still to this day, found it in my service records. Dealer notes state “they don’t hear anything”...
  3. Nov 14, 2018 at 3:28 PM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    I heard a story here recently about a lawsuit where dealerships were sending out “fake” recalls to get folks to come in and get extra service. Maybe it’s one of those??
  4. Nov 14, 2018 at 3:28 PM
    blackz151
    blackz151 New Member
    nick
    I work at a dealer in parts. We do this recall all the time. The tech will pull the window switch and fill up all the wire ports with more grease. If it looks like there is any burn marks or the window switch is broken the will replace it with the new one.
    The recall sounds like bs but I can honestly tell you Ive seen more then a couple of switches that are burnt and melted. I wouldnt say you should rush over and do it but if your in for service or have a couple hours I would get it done
  5. Nov 14, 2018 at 3:30 PM
    SOB
    SOB Big Member
    Ohio
    I (quickly) stand corrected!
    Black Wolf likes this.
  6. Nov 14, 2018 at 3:39 PM
    Glad I have an 07..heh..heh. Yep..that recall is legit. Worth getting done.
    OBXTundra[OP] and blackz151 like this.
  7. Nov 14, 2018 at 5:22 PM
    OBXTundra
    Southeast USA
    I figured it was a legit recall. I read about it in other forums and blogs.
    It's toyotas solution that I question, coating connections with more dielectric grease doesn't sound like a solution.
    Why is the switch overheating?
    Where is resistance being generated to cause heat?
    Read something about replacing a circuit board as well.
    I was really looking for others that have had it done already.
  8. Nov 14, 2018 at 5:44 PM
    fairclothr1
    fairclothr1 Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    I have a 2009 and just checked my account on my Toyota Owners app. No current recalls and no work in the history on the window switches.
  9. Nov 15, 2018 at 4:54 AM
    blackz151
    nick
    Honestly I dont know why I think its a silly fix as well. I just re read the recall again to see if I could get you some answers and its pretty useless. I believe the problem lies in the window motors. The recall calls for 3 screws(to screw the switch back in) and grease but can be inspected by the tech and may require a board to be replaced.
