Window Auto Down but not Up
Discussion in '3rd Gen Tundras (2022+)' started by TundraDan723, Oct 4, 2023.
  1. Oct 4, 2023 at 7:39 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I thought I read somewhere that you could adjust this feature, however after searching I could not find anything.
    My issue is that a single press down on any of the four window switches will open the window completely. A single pull up of the switch will close all windows up EXCEPT the drivers window. The drivers window takes a second pull for it to auto up completely.
    Is this something that can be changed without taking to the dealer?
  2. Oct 5, 2023 at 3:40 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    If the driver window isn't functioning, it's most likely stopping due to resistance. I don't know the Toyota process, but other manufacturers can usually be recalibrated by rolling the window down and hold the button for 3-5 seconds, then roll it up and continue holding the button up 3-5 seconds.
    I know my driver window is really picky, if I hit the smallest bump while moving it will cancel the auto up feature.
