Window-3rd brake light leak in rain
Discussion in 'General Tundra Discussion' started by dheselton, Apr 25, 2024.
  1. Apr 25, 2024 at 3:36 PM
    dheselton
    dheselton [OP] New Member
    2016 Tundra SR5
    Hi
    I’m new today
    I have a 2016 Tundra SR5 with 140K and in good condition, but has started to leak water at the back window above the rear seat.
    Not sure where it’s coming from?
    Rear window? 3rd brake light?
    Thank you
  2. Apr 25, 2024 at 3:40 PM
    seydou
    seydou Distinguished Member
    Not uncommon for the brake light to leak. Remove, reseal and replace.
  3. Apr 25, 2024 at 3:43 PM
    dheselton
    2016 Tundra SR5
    Any info on how to repair/replace?
  4. Apr 25, 2024 at 3:49 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  5. Apr 25, 2024 at 4:23 PM
    Culprit is usually the 3rd brake light.
  6. Apr 27, 2024 at 11:05 AM
    HelpDeskDerp
    HelpDeskDerp New Member
    2021 Tundra SR5 CrewMax
    Same thing happened on my 2016 Tacoma. Dealer said there was a bad batch of gaskets for the brake light out of the factory during 16 that essentially dry rotted out. Toyota replaced at no charge due to known issue.
  7. Apr 27, 2024 at 11:25 AM
    j-utah
    j-utah performance warrantied member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    OP, with the Tacomas around the same year, the brake light seal replacement is a recall item. They replaced with a thicker gasket. Could be that there’s a recall on the tundras as well.
